Results 1 to 3 of 3
Thread: Lifting out the engine
    Dec 2010
    Kiewa Valley, VIC
    Hi all,
    Best wishes for the new year.
    Anyone like to recommend an effective way to lift the 2.0 ltr motor?
    Where is the best place to fix a chain the to motor, or the best location for a pair of slings?
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    Bunbury, WA
    I placed a chain around the complete unit with a steadying strap around the front pulley.
    My major issue was that the bulkhead had to be released on one side and lifted about 2" to provide clearance for the gearbox to clear the chassis crossmember.
    Timj is offline Wizard Silver Subscriber
    Brisbane,Qld.
    I haven't taken out a 2 litre but they would probably be the same as a 2.25 which I have taken out many times. It is much easier to seperate engine and gearbox and the gearbox then come out through the passenger door if need be. There should be two engine lifting points one on the front of the engine and the other on the back, basically flat steel loops. I usually use rope to each one as I can adjust the level by changing the knots. I also have a levelling bar with chains and I sometimes use that but it doesn't let the engine get right back to the firewall and can get in the way a bit.
    TimJ.
    Gumnut - 1953 Series I 80"
    Poverty - 1958 Series I 88"
    Arnie - 1975 710M Pinzgauer
