Results 1 to 10 of 21
Thread: Traxide isolator earth wire on/off switch
    Oct 2014
    I have one of the older SC80 isolators from before a switching module was available. Sometimes the D4 sits unused for 3-4 days and can get a low voltage warning as a result.
    I do charge the batteries every month or so but would rather turn off the isolator when it's not needed and I'd like to add a switch to make it simple.
    As I understand things, just adding an inline switch to the yellow/green earth wire will do it. Has anyone else done this? I am considering something like this switch from Jaycar.
    Regards,
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Jan 2015
    Hi Scott,
    This was discussed a bit in this thread: Battery failure #2 grrr
    I haven't quite gotten around to this yet but I was thinking of just adding one of these connectors inline: 1sets of 1 Pin Way Car Sealed Waterproof Electrical Wire Auto Connector Plug Kit | eBay
    I do like the idea of a switch too but hadn't worked out the best way to mount it so it isn't bouncing around...
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Queensland
    Hi Scott and David, you can use any type of switch and it does not have to be waterproof.
    Your switch will be haddling less than 250ma.
    A micro toggle switch would be ideal and because they are so light, they do not have to be mounted, just fit one in-line and make sure the switch terminals are covered.
    Sep 2012
    Adelaide Hills
    ive done it in the d2
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Oct 2014
    Any photos?
    D3 2005 V8 Petrol
    Jan 2015
    I quite like the look of these - nice and small and will work nicely inline. Depends on the quality and how well they 'latch' whether it's a good option. Could possibly just glue to the side of the isolator case too.
    10Pcs 12*8MM DC 1A Black On Off Mini Push Button Switches For Electric TorchWG | eBay
    Just bought some so I can check them out. I'll report back.
    David
    Apr 2010
    Northern Victoria
    A small toggle switch and attach it to where ever it suits with silicon.
    Ivan
    2005 D3, 245/70/17 STmax, Tvan, Traxide, Mitch hitch
    Oct 2014
    Quote Originally Posted by l00kin4 View Post
    David, I like your idea maybe even more than a switch. Can buy with wire tails so even easier to install.
    D3 2005 V8 Petrol
    Brisbane,some of the time.
    I have a normal light switch mech,taped up sitting next to the battery.
    Its been there for over 5 yrs,with no issues.
    St Helena,Melbourne
    4.28 MB
    What is the benefit of adding a switch, i would have it better to have both batteries linked so they can balance ?
    Wouldn't adding a small solar panel or trickle charger be a better solution.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
