Results 1 to 10 of 39
Thread: Anyone use fuel treatment / cleaner ?
    Ean Austral Guest
    Gday All,
    just curious if anyone uses a fuel treatment/ conditioner / cleaner or whatever you wish to call it.
    if so which one and do you think it’s worth it.
    Cheers Ean
    Apr 2015
    Hervey Bay
    Yeah I use fuel system cleaners sometimes.
    I remember watching a 5th Gear show where they tried to restore the horsepower of an older car. The biggest improvement the got was from the $10 bottle of fuel system cleaner.
    So every now and again I'll put a bottle of cleaner through the cars, but only if supercheap has a good special on or I'm feeling rich.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    Brisbane, Queensland
    What I’ve used.
    I use something almost every tank.
    It’s difficult to know if any of them make a difference. I think they do. My L322 tdv8 has over 280k km and no fuel tank sensor, fuel pump or injector problems that I know of.
    I recently used CEM FTC decarboniser which seemed to make the car run quieter/smoother. But also did a CEM oil flush which has resulted in engine oil staying much cleaner. So that may make the engine quieter/smoother too.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Sep 2014
    Baldivis WA
    Yes, Penrite diesel injector cleaner every once in a while (say every 3 months or so). After a road trip where we picked up some water in the fuel, I changed the fuel filter and put through one of these cleaners, worked a treat.
    I’ve also recently put in one of those complete fuel system treatments, from liquid moly, penrite or one of the other reputable brands. I stay away from the generic or store branded products.
    I also use the penrite engine flush at every oil change, and just last week, for the coolant flush and change, also used the radiator flush product.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    I use the cost effective maintenance stuff and he is a user here.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    I've been using "Lucas Oil - upper cylinder lubricant & injector cleaner" for quite a few years now, the Lucas rep gave a talk
    at the Victorian Landrover club meeting and handed out free samples... I tried it ....and my engine "seems" quieter and "seems" to run a tiny bit smoother
    so I just keep on adding it to every tank of diesel...
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by Eric SDV6SE View Post
    Hi all
    I was doing a search on Penrite engine flush and Eric's post came up. I am considering doing this on my 300Tdi at the next oil change but when I looked on the Supercheap site it said this product is not compatible with my vehicle which contradicts the blurb on the Penrite site.
    Does anyone have any experience with this product in a 300Tdi? Also considering the radiator flush....
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Jan 2018
    Lilydale, Victoria
    Quote Originally Posted by incisor View Post
    can you be more specific please?
    David
    Sep 2014
    Baldivis WA
    Quote Originally Posted by travelrover View Post
    Hi all
    I cant see why this engine flush is not suitable. I just did the same SCA comparison and whilst it says the Penrite flush is not compatible, the Wynn’s and Nulon products are. I’m sure all are very similar. Best bet is an email to Penrite.
    Personally, I wouldn’t have a problem to use it, same as the coolant flush treatment.
    Oct 2013
    Richmond, NSW
    Thanks Eric
    I thought it would be fine and had no reservations until I saw the Supercheap statement. Think I will just go ahead. All the oils on all my Defenders are Penrite as I believe they are good products :-)
    Travelrover
