Thread: Persistent turbo oil drain flange leak
    Sep 2014
    Baldivis WA
    Dear Brains Trust,
    I ve been battling a persistent oil drain flange leak on the passenger side turbo of my SDV6 SE for the past few days. Ordered new gaskets from the UK before Christmas with the plan to replace the one at the turbo over the last week. Leak has been “minor”, but drips onto the front driveshaft and is flung everywhere.
    Replaced the old gasket last Thursday, refitted and torqued to specs (10Nm as I understand). Now leak is worse. Replaced again today with another gasket (ordered two just in case). Used Permatex Form-a-Gasket no.2 on the flange faces and Loctite 609 on the bolts. retorqued to spec and again after test drive an cool down. leak persists.
    Any ideas?
    thanks in advance
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Eric SDV6SE View Post
    Dear Brains Trust,
    Any ideas?
    thanks in advance
    Dumb question. Are you *sure* that is where the leak actually originates (says he who dropped, rebuilt and reinstalled an entire transmission in the driveway to fix a leak that turned out to be a pinhole in a cooler pipe).
    Mar 2016
    I stared under mine yesterday trying to find an (or one of many) oil leak/S. Much like Brad suggested, needle in a haystack.
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    Quote Originally Posted by BradC View Post
    Good question Brad, AFAIK it’s from the flange, but could also be from where the flange meets the pipe. The top side of the turbo is clean and dry, so it’s not the supply oil pipe. When viewed from underneath, oil drips from the flange bolt furthest from the engine, I.e. wheel side, so I believe it’s leaking through the bolt hole in the flange.
    will keep searching
    Mar 2016
    will keep searching
    The thing to consider is why? Why would it leak there? It’s not under pressure at that point (downside of the turbo bearing). Stating the obvious but capillary flow and motion/wind effect will cause it to move a lot. Anyway, you’re a capable chap so you know this. This is why I’m ignoring my leaks Persistent turbo oil drain flange leak
    2007 Audi RS4 (B7)
    Mar 2016
    I took a peek into this. Maybe consider getting some UV dye to trace it. For about $50 you can get a light and a small bottle of dye on eBay. Seems like a good way to find complex leaks
    2007 Audi RS4 (B7)
    Jan 2009
    Perth, WA
    Drain pipe leak
    will keep searching
    Hi Eric
    My indie replaced my turbo drain pipe with the new/modified version during one of my services (wasn't leaking, but he did it as a preventative item before blocking/failure).
    When I got home, it was leaking a little bit of oil.
    I took it back to him and they spent quite a few hours searching for the source of the leak.
    Turns out that there was a very small (hairline) crack in the flange that opened up slightly when it got hot - enough to let a little bit of oil out.
    Not sure if that's common, but I thought they did really well to persevere and find it - as it was only happening when the engine warmed up...
    Thanks.
    Rob
    D4 3.0L SE, MY10, Arctic White
    ARB Colour-coded bullbar, Safari Snorkel, Traxide DBS, LRBT1 BT audio module, trying out some 19" Maxxis Bravo 980A/T's (ex Cooper Zeon LTZ's)
    ex D1 2.5L 300Tdi, MY97 - loved it, gone to a better place.
    Sep 2014
    Baldivis WA
    Thanks Rob, I suspect mine's the same. Will investigate on Saturday..
    Wouldn't happen to have a part number by any chance?.
    Sep 2014
    Baldivis WA
    OK, so I revisited this again. Cleaned everything down, retightened bolts to spec then ran the engine up to operating temperature in the garage. Still leaks.
    Let it cool then torqued bolts up to 20Nm (double the spec). Bolts are 10.9 grade T30 torx, I wasn't worried so much about snapping the bolt, but rather stripping the thread in the turbo flange. Anyway, all good, no broken bolts etc.
    Ran the engine up to temp again, thought I had it sorted, as at the same temperature no oil leaks. Refitted heat shields and went for a drive to get the turbo hot.
    Result below:
    Still leaks....
    Took it into LR yesterday for their advice and help. They replaced the existing drain pipe with a new one, plus double gasket on the turbo drain end.
    Apparently the pipe and flange were OK, slight kink in pipe near the sump. Turbo flange also OK.
    No more leaks, and all done at no cost.
    Double thumbs up from me to my local LR dealer.
    Mar 2016
    Great work by the dealership. A very unusual issue I must say. I wonder if the flange face of the drain had somehow deformed from flat? Anyhow, sorted. On to the next issue (well it’s a Land Rover. It’s all about prioritisation of what to fix next).
    2007 Audi RS4 (B7)
