A/C issues - Td5 and 300 Tdi
Hi all
The recent warm and humid weather has highlighted some A/C issues I am having. My Td5 is now only pumping out warm air (well its hot really) no matter what setting the dials are on. Usually a fraction under max cool and full fan. But over the past few weeks or so even after being running for 30 mins there is no discernible cool air coming out of the vents. In the cooler temps it seemed to work ok but not brilliantly. I have owned this one since new (MY99) and don't recall the A/C ever having been serviced. Maybe now is the time!
With the 300 Tdi ('96) the A/C was working (albeit with a small leak in one of the pipes) but now is completely dead. I have replaced the fuses in the main fuse box. (Are there any under the bonnet?) but no change still dead. All the wiring I can see appears to be ok but without isolating and jumpering past sections I cant be sure. Could it be the switches have failed after 23 years?
Any guidance/suggestions would be appreciated.
Cheers - Simon
Travelrover
Adventure before Dementia
2012 Puma 90 - Black
1999 Td5 110 Ute - White
1996 Tdi 300 Wagon - White
