Results 1 to 10 of 11
Thread: Fuel leak 2.7td
    Jul 2013
    Fuel leak 2.7td
    Hi all, my D3 has developed a fuel leak from the rh cylinder bank. I can't see the leak source from the top yet, but its leaking down the engine and appearing on the rhs underneath. I suspect it may be leaking from a line on the fuel rail, but until I can pull a few things off I can't yet tell. Any suggestions?
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Ean Austral Guest
    Theres a few clamps on that side , wonder if its rubbed thru .
    Sorry cant offer much more help
    Cheers Ean
    Kingston, Tassie, OZ.
    Many fires have been started as a result of high pressure misting of already warm diesel floating around the exhaust system and especially the turbocharger ...
    Can we all say "flash point"...😲
    Jul 2013
    On the plus side insurance excess is probably cheaper than a repair...
    Shane
    Mar 2016
    Quote Originally Posted by shanegtr View Post
    Fuel leak 2.7tdFuel leak 2.7tdFuel leak 2.7td
    2007 Audi RS4 (B7)
    Jul 2013
    Got to have a decent look this evening, found the leak at cylinder 1 injector return line so only a low pressure leak and at least it's not spraying hp fuel everywhere
    Shane
    Mar 2016
    Have you ever had the injector out to change the manifold etc, that might explain the leak?
    2007 Audi RS4 (B7)
    Jul 2013
    Nope, nothing since I've owned it.
    Shane
    Jul 2013
    Changed out the injector return lines today, all appeared to go fine until starting it up. While there are now no leaks I'm now getting an injector control pressure to high fault. Tried changing the fuel filter but no go, still the same.
    Shane
    Oct 2014
    Does that suggest a blockage on the return side causing a pressure spike?
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
