Results 1 to 10 of 13
Thread: SDV8 Service Intervals
    Feb 2010
    Mount Martha
    Hi all,
    Did a search and couldn't find what I was looking for.
    Just wondering if all SDV8 owners get their service done at 26,000 Klm's as per the book, or at less intervals?
    Thanks in advance
    NSW SW Slopes
    My TDV8 gets 10K oil and filter changes.
    Aug 2014
    SW Victoria
    I get my TDV6 done at max 1 yearly intervals, mostly quite a bit less than the recommended distance. The same for other vehicles that I run. The service 'consultants' always look at me as if I am a dill but I reply with "it is my car and my money". The actual techs if you can get to speak with them are more comfortable though.
    Cheers Simmo
    Kingston, Tassie, OZ.
    10k for me. Oil is cheap.
    Feb 2005
    What about the labour of your mechanic... SDV8 Service Intervals
    Feb 2010
    Mount Martha
    I hear you..........the SDV8 has a massive oil capacity of 9.4Lt which means that it shouldn't contaminate as quick as most oilers, however I think I would rather spend the extra $ and have it changed (inc filter) every 10,000 Klm's.
    Cheers, Craig
    May 2003
    On The Road
    What its duty cycle? If it runs across (and I mean across) the country all its life then 28K is probably reasonable..
    If you live in a city and drive it to work every day then 10K would be much better.
    NSW far north coast
    This ^
    Brisbane, Queensland
    What is the oil spec for a 4.4 tdv8?
    I agree $85 for oil once a year is less than a tank of fuel.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    NSW SW Slopes
    For my non-DPF 4.4 TDV8 L322 its the same oil as the non-DPF 3.0 TDV6.
    I buy it in 20L drums form the local Castrol distributor with a recent drum costing $146. Back in 2010 when buying it from the same place as a special order for my 3.0 TDV6 it cost nearly $400.
