Results 1 to 10 of 18
Thread: Disco 4 round plug to Anderson plug adapter + brake controller
    Mrhigherbeing Guest
    Hello all
    I’m looking for a link to where I can buy a round plug adapter to an Anderson adapter so I can plug my camper trailer electrics in (I know about the worry of amps it’s purely to keep battery topped up).
    Also wondering if anyone has advice on a good brake controller?
    Cheers all
    Ian
    I don't know if there is such an adapter. However it would be very easy to make one.
    Oct 2012
    DISCO3.CO.UK - Shop
    martin@disco3.co.uk
    They will make up a plug with whatever end you want.
    I had an Anderson to 12S off the switched supply. It’s fused also (I think).
    Sep 2014
    Baldivis WA
    Tekonsha P3 brake controller
    TEKONSHA P3 PRODIGY CARAVAN TRAILER ELECTRIC BRAKE CONT
    Also check Ebay.
    I've had this in my D4 now for over 5 years with no issues.
    DiscoMick Guest
    Any auto electrician should be able to make a round to Anderson.
    Add my vote for the Tekonsha - neat bit of kit.
    May 2016
    I have had a P3 for several years. Great bit of kit.
    The Redarc Towpro takes up less real estate, but I’m unsure how good they are.
    Normanhurst, NSW
    Quote Originally Posted by Mrhigherbeing View Post
    Hello all
    Cheers all
    Ian
    Have you considered replacing the large round Utilux power socket with an Anderson plug/socket?
    No need to worry about adapter leads then.
    Roger
    DiscoMick Guest
    I have a flat pin plug for operating the trailer plus a separate Anderson plug for charging it's batteries.
    Jan 2017
    Whitsundays
    From my own recent hard learnt experience that size cable from the large round will not top up your batteries at all. I think that’s what you said you wanted it for. It may run led lights etc. Perhaps bite the bullet and have a dedicated Anderson plug at the rear. Fairly uncomplicated install. I ran just one big positive from battery and a big short ground to a earth screw shared by the spare tyre winch and it works perfect. Even reasonable size cable is pretty useless. Use BiG cable (5mm ID) and fuse it. No need for dc dc charger then either. I know that’s not what you asked but I don’t think what you want to do will work as you hope.
    Good luck Steve
    Mrhigherbeing Guest
    Thanks all, good advice
    I’ll bite the bullet. Cheers y’all
