Results 1 to 2 of 2
Thread: Series Salisbury Diff
    Mar 2013
    East Gippsland
    The drive flange end seems a bit ify in the way its assembled, my parts manual, and an online supplier show more pieces, but my Haynes manual shows what I have.
    IMG_4393.jpg one slightly dished washer showing scoring both sides IMG_4394.jpg IMG_4395.jpg
    Oil seal IMG_4400.jpg will replace it was flogged out
    Drive flange (with reasonably good nick Speedi Sleeve)IMG_4402.jpg washerIMG_4403.jpg IMG_4404.jpg
    Why is the large washer scoring and should it be cupped.
    Cheers Paul
    Hay Point
    That slightly cupped washer behind the seal is an oil slinger to keep oil away from the seal. It should be straight and I would say it has been damaged / bent by repeated seal removal/replacement over the years.
    Cheers......Brian
    1985 110 V8 County
