Results 1 to 10 of 23
Thread: USB Install rear seats
    Dec 2015
    Portland
    Hi all
    Installed this in rear seats replacing cigarette lighter fitted perfectly came pre wired.Now have dual usb & 12v & voltmeter . Bought off wish app for cost of about $20 delivered
    Mar 2016
    Brisbane Queensland
    wish app ? please explain. I would like one of those.
    4.28 MB
    Do yourself a favour and check the current draw of the Voltmeter. I had a dual voltmeter when Tim from Traxide advised me to remove it because it draws about 1 amp
    Rod
    D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
    Dec 2015
    Portland
    Wish app is a shopping app download from your app mine is from android .Also bought these of it. Tyre pic below
    I will keep an eye on the current draw ,its only on when driving, I also have the bluetooth battery monitoring app so will watch out ,each bit can be replaced with another
    USB or 12v socket if it drains to hard thanks rodUSB Install rear seats
    Normanhurst, NSW
    Quote Originally Posted by rocket rod View Post
    Or put a switch in the voltmeter circuit.
    Roger
    Sep 2014
    Baldivis WA
    The Wish app is good.
    Do you have the part number for this please?
    I personally would get 1 x 12V socket and 2 x 2 USB ports instead of the volt meter.
    Wouldn't the volt meter always show 14.5V when the car is running?
    Dec 2015
    Portland
    Quote Originally Posted by Eric SDV6SE View Post
    3 in 1 Car Motorcycle Cigarette Lighter Socket Outlet + 4.2A Dual USB Charger Power Adaptor +LED Digital Voltmeter
    couldn't find part # but there is a few different options with different setups if you look through the app.
    when ignition turned on its about 12v then with motor running its sitting at 14.5v .
    Also have ordered a single dual port to replace 1 of the 12v outlets in front seats .
    Sep 2014
    Baldivis WA
    Cool, thanks. I was using the 12v plug in USBs at the front, but the connection is dodgy most of the time. Will get the ports for the rear and front, will make it easier to charge stuff.
    Mar 2016
    No. Smart alternator so the value is anything from 12.0-14.7V depending on the batteries state. When the car is started, for the first 30 seconds it doesn’t start charging with the alternator, presumably to determine the current draw and battery state of charge before deciding on the alternator output required.
    2007 Audi RS4 (B7)
    Normanhurst, NSW
    Be careful of shipping charges and slow delivery. Similar items can also be found on ebay for less & ofen come with free shipping.
    Roger
