Results 1 to 10 of 11
Thread: cv busted - are maxi drive stronger 'with pics'
    Feb 2005
    hey
    busted the driver side cv over the weekend, long story.
    my mate said i could get it rebuilt or an exchange, i figured seeming i have fitted maxi drive axles to the rear i might do the some for the front as i assuming the maxi drive cv's would be beefed up more the standard ones. please advise
    Melbourne - Eastern sector
    CV's and stub axles are a good fuse and much cheaper then gboxs.... uni's are a pita to change out in the bush..... it all depends what driving you are doing....
    Feb 2005
    im not into the real tough stuff, i normally engage the lockers so that i can just cruise up hills and elimate wheel spin and look after the drive train i.e. i don't have to jump on the gas. will ring around for prices tomorrow.
    South Sydney
    Weeds -- I think Maxi just recommends fitting the County 110 CVs which are much stronger than the Defenders (Part No: AEU2522).
    ____________________________
    Noddy
    - 'Kimba' ('02 Defender Xtreme 110)
    - 'Ari' (1994 Peugeot 205GTi Classic)
    "...we are all just earrings to the left of our parents, and they are all just haircuts to the left of theirs..."
    cvs
    Drive line services in brizzie do a reco 110 cv which is well priced, I have used them with comp trucks have never broken one, plenty of diffs though. The maxi drive units I think are genuine rover items.
    glen
    Nanny state UK...
    Maxi Drives should be stronger but be warned.... You may well just end up breaking the next weak point in the drive train (which is what Mick was saying). It's a lot easier dealing with a busted CV rather than a busted gearbox!!!
    The CV that you busted... Was it a Genuine one or an after market one? If it was an after market one then get yourself a genuine parts one. (The Genuine ones are usually a bit stronger than the after market ones.)
    Mark.
    Feb 2005
    do these fit straight in or do i need different drive flanges etc all the splines in my broken one are in good nick
    camel_landy re: are they orginal not sure only had the rig 18 months
    discoute, thanks for the lead, will give them a ring
    will do the ring around tomorrow
    Nanny state UK...
    Just read your comments about how you broke it...
    One thing I will say, you're better off engaging the rear locker first and then only engaging the front in extreme conditons. Your drive train will feel much better for it...
    Mark
    Feb 2005
    Mark
    i don't think the wife will let me forget moment of sillyness
    Feb 2005
    Re: cvs
    glen
    just rang driveline services and they do not have a listing for 110 cv's, they said if i wanted i could bring in the bits and pieces they would have a look.
    best price i have so far is $350 new / $175 second hand
    apparently the county cv may not be as good these days as GKN no longer make them
