Thanks to SLT who replied via a PM that his was 2.25m high
Looking forward to any other replies
Hi Folks
Looks like I'm buying a Dual Cab Trayon to put on a 130. For those who have one mounted on a 130, would you mind helping me with a few measurements please
- Height to top of Trayon, including top channel
- Tray height from ground
- Height of Drawers under Trayon
- Suspension Lift
- Tyre size
My carport is 2.4M high, on a steep slope. I am expecting to have to modify it, but probably can't go much beyond 2.5m. I'd like to mount the spare under the tray
Any pics of your 130s from the rear would be appreciated.
Rod
'95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
'85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
'76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
Ranga should pipe in soon......he has a 130 with trayon.
Not having a go here.
This will be easier for you do the measuring/ math yourself.
I recall the trayon measurements are on the site.
The height is different on all traybacks unless fitted by the same body builder and even then probably some variances.
Suspension height, tyre size and tray height are unfortunately irrelevant from any other vehicle, but yours. Tyre manufacturer and pressures alone will change your height by 20-25 mm.
When you’ve figured your final tray height after suspension and tyres, allow another 50mm to compensate for loaded vs unloaded.
And no we don't own a Trayon ours is self built.
Series Landy Rescue
Our FB Page..
