Results 1 to 10 of 14
Thread: Speedo reading
    Sep 2017
    Lysterfield Victoria
    Speedo reading
    Hi all, I have just gone to s 245 75 16 from 235 70 16 on my 02 Td5 Disco. Has anyone got an idea how much the speedo will be out if any? I thought there was a chart but couldn't find one when searching. Cheers Brett
    Sep 2011
    About 5% from memory
    99.87 MB
    Yep, 5% (5.2%)
    Slunnie
    Jul 2014
    west of Transylvania
    5.2% according to this tool Tire Size Comparison
    DiscoMick Guest
    A GPS used while driving should show the actual speed.
    Jan 2017
    Geraldton WA
    Quote Originally Posted by DiscoMick View Post
    Be careful when relying solely on a GPS for your speed because they Can be wrong at times.
    I recently fitted a HUD GPS unit in my Navara and this gives me a reading that is higher ( about 2-3% faster) to the speedo reading in the truck But the HN7 unit is saying that I am travelling 5-6% slower.
    So at a speedo reading of 100kph the HUD is saying 102-103kph and the HN7 is saying 94-95kph.
    I have 265/75/16 tyres fitted to the Navara But a 70 profile is stock which should give me a faster speed than the speedo is telling me so I am pretty sure that the HUD unit is more accurate than the GPS readout on the HN7 unit.
    I have a spare Garmin street GPS that I might hook up and see what that reads at out of curiosity.
    If you are travelling AT the speed limit then it is critical to make sure you KNOW exactly what speed you are travelling at But as I generally travel about 5kph slower than the posted limit I haven't had a problem with the boys in blue.
    4.6m Quintrex boat
    Apr 2016
    Country Vic.
    also be careful to differentiate between theoretical, and actual % differences.
    Using the calculator, it calculated that when I went from 255/70 to 245/75's I'd have a 1.5% drop in indicated speed, whereas I a 1% increase in the speedo reading.
    There will be differences between tyre manufacturers .. most likely due to the design of the tyre.
    If you have a smartphone, there are many apps that can use the GPS in the phone(if it has one) to give you an idea of your speed differences.
    For Android I use GPS Test.
    I think some iPhones don't have GPS built in tho.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Back down the hill.
    Be careful with all aspects, tyre diameter will vary from model and brand to model and brand, making theoretical calculations iffy. Tyre pressure will also effect this.
    GPS is historical information, generally close enough to keep you out of trouble, but particularly unreliable in heavily treed or steep (cuttings etc.) terrain. Tall buildings and tunnels can and do interupt the signal.
    The most reliable way to mentally calibrate the speedo is on a level road note its reading after the GPS has remained constant for at least 5 seconds.
    NSW far north coast
    Quote Originally Posted by AK83 View Post
    Totally, and sometimes differences between batches of the same make/model.
    The indicated the size of nominal, not actual.
    DiscoMick Guest
    Yes, all true. Another factor is the margin of accuracy in GPS. I read that the military signal is much more precise than the civilian version, but I can't remember the details.
