Results 1 to 10 of 17
Thread: Tex Magna indicator unit - rubber wheel replacement
    Jul 2016
    Hi All,
    I bought a new rubber for mine, but my wheel is riveted together, so I was wondering if anyone has replaced the rubber on a rivited wheel ?? I have seen some wheels are held together with bolts, but not mine.
    Any clues welcome.
    Aug 2010
    Sunbury, VIC
    Think I did this on a friends unit some years ago, but can't recall what we did in the end to be honest - Drill the rivets out and replace with nuts and bolts?
    Jul 2016
    Yeah, that's what I was thinking too, as there seems to be plenty of room for that. The other method I just read about was to just get a big screw driver and twist it to separate the two metal halves, then I guess you can kinda recycle the rivets.
    Narre Warren South
    I've seen a few threads and they drill out the rivets (is it a rivet or does one side have the stems as part of the casting and these are peened over when the other side is positioned ?).
    Have you found a source for the rubber wheels, I've seen them in Ebay it would be good to get some feedback on how the reproduction ones last.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    australia
    Quote Originally Posted by JohnboyLandy View Post
    Hi All,
    Any clues welcome.
    if you need rivits i have contacts in the uk jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Narre Warren South
    Just had a look at one.
    One side is diecast with 4 protrusions which have hollow ends.
    When the rubber is in place a steel plate with 4-holes sits over the protrusions which are then flared, like a rivet.
    To take apart I'd drill off the flared ends and it will pull apart.
    To re-join you'd probably have to remove the protrusions then you have a choice of drilling 4 holes and using solid rivets, pop-rivets or small screws & nuts. There might be enough thickness in the diecast part to tap a thread so you could use some small screws to re-assemble (M3/M4 if you don't have BA screws).
    Interested in any feedback on rubber wheels, I have a number of Tex-Magna's to repair.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Adelaide Hills. South Australia
    .......and if you really get stuck my still unused replacement was supplied by .....
    Pangolin 4x4 @ Pangolin 4x4.com Rubber Turn Signal Wheel Replacement Kit is Part#522882
    I bought it some years ago but never fitted it because I found wrapping a piece of Velcro around the column then gave sufficient grip to use the worn out wheel.
    You have now reminded me to pull my finger out & do it.
    Pangolin 4x4
    I have not had to do it, but my approach would be tu turn up a wheel out of aluminium, and provide a groove to fit a suitable O-ring. Probably have to fiddle about a bit to modify the design while doing this!
    Narre Warren South
    They are on Ebay
    Land Rover Series 1 2 2a Indicator Tex Magna Rubber Wheel | eBay
    I'd like to know if they are any good though....
    I like John's idea, you'd probably have to use the diecast part & spindle then turn up a disc that rivets/screws to it with a groove for the O-ring. Glue the O-ring in place so it doesn't move but could be removed in the future to replace it.
    Maybe a model supplier has a pulley that could be modified........something else to track down !
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2016
    Thanks for all the input guys.
    Yeah Colin I have a new rubber already, there are several ebay sellers selling them, so I probably just went for the cheapest. I can't imagine they vary at all.
    I have seen an article where a guy uses a sink plug to make a new rubber for the wheel !!, but I'm going to try the rubber I bought.
    I'll drill out the flared ends of those rivets/posts and go from there. Tapping a thread is a good idea, might give that a go.
    I had my Tex Magna Lite housing chromed, it looks pretty schmicko !!
