Is it the key that is stuck or the towbar tongue
Here is an extract from the Owners Manual
1. Insert the key and turn it clockwise to
unlock the tow bar.
2. To remove the tow bar, pull the handle
outwards and rotate the handle
anticlockwise until a click is heard. The
marker on the handle should show red.
3. Carefully lower the tow bar and place it in
its stowage area and fully secure it.
4. Replace the protective towing cover in the
tow bar mounting. Press the bottom of the
cover to fix it in position.
Also when lowering the spare Dont wind out the winch cable too far or it will double over and seize the mechanism
