Results 1 to 9 of 9
Thread: anyone around
    sydney
    anyone around
    hi all
    i have four days off work next month 5th may to 8th is any one out on those days were i could tag along or anyone want to go out, please bear in mind im using my disco which is standard and used for work so nothing to extreme, im also new to thearea so will proabaly need to tap your knowledge of were to go.
    ohh im in sydney, perth and adelaide might be a bit far for a day trip
    Padstow NSW
    hurry up and fix that bloody 90!!!!
    im trying to plan a watagans trip on the 6-5-05.
    phil.
    May 2002
    Sydney, Australia
    are we still on for the 6th?
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    May 2003
    On The Road
    no pressure muddymech :roll:
    Padstow NSW
    <div class='quotetop'>QUOTE</div><div class='quotemain'>are we still on for the 6th?
    LRH[/b][/quote]
    yep, last play date b4 i drive back to QLD for 2 weeks.
    ITS ALL UP TO IAN AND LOU!!!!!!!
    cheers phil
    May 2002
    Sydney, Australia
    LRH
    cheers phil[/b][/quote]
    QLD AGAIN!!! - your not another one moving back???
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    Padstow NSW
    not yet!
    just a visit.
    phil
    hey guys your not waiting for me!!!
    as i had the time off from work and marcel said he had to cancel so after trying to get the time off from work i had to sheepishly cancel the day......
    and then ian found out that he was off!!! so that is why ian is off and i'm not...........but depending on whether it is still a 90 event or not depends on whether ian is coming......
    as the reeality is the 90 is probably not going to be ready by then so if it is open for anyone then ian may come but it will be in the disco.
    dullbird
    Padstow NSW
    yep you can still come! even if its in a disco :roll:
    the 90 trip started off well, at least 6 90's, but their dropping like
    flies 8O
    so im down to maybe 3 8O
    thats ok, im turning it into an anybody trip.
    better get my rear into gear and put this up in the trips section.
    phil
