Thread: Air strut valve
    St Helena,Melbourne
    4.28 MB
    Air strut valve
    I need to release air from one strut , do I need to undo the airline on the strut or valve block or somewhere easier ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2016
    Gap IID can deflate the system. Presuming you don’t have access to one?
    2007 Audi RS4 (B7)
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by DiscoJeffster View Post
    I have one but not registered it yet so don't have full functions.
    1974 VW Kombi bus
    NSW SW Slopes
    Last that I knew, the Gap tool only deflated all 4 corners which didn't suit my need.
    Unscrew either the connector at the air strut or at the valve block whichever is less inconvenient until air starts leaking at a reasonable rate then wait until the flow decreases to very little before unscrewing completely.
    St Helena,Melbourne
    4.28 MB
    Did it at the valve block as it was easiest to access, job done along with an oil/filter change.
    1974 VW Kombi bus
