Results 1 to 9 of 9
Thread: need help , transmission or front shaft issues ??????
    cqguy Guest
    hi guys
    i am not mechanically minded at all and need a bit of help determining an issue . right i was driving along then got a grating noise/scraping noise from front of car (possibly just below passenger seat maybe a bit more forward ) and lost power to the wheels , it then stopped gave me power back and as i wasn't far from home headed that way but before i got there it happened again only this time instead of going away it gave a great clunk from around the same spot and didn't want to play anymore . now the motor goes A ok it changes gears A ok but wont actually give me any power to the wheels , would i be right in saying that the front shaft has done its bearings (not even sure if it has bearings) or should i think along other lines . just looking for opinions before i ask a mate to help me start pulling her to pieces unnecessarily . and if it is a problem with shaft will removing it allow the vehicle to operate as a 2 wheel drive via rear diff only .
    thanks in advance to anyone that can possibly point me in right direction
    Manly QLD
    photo is a Range Rover Sport ? (aka Disco3/4)
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by cqguy View Post
    hi guys
    We talking about a Range Rover L322 or the Range Rover Sport here as the pic suggests? They are 2 very different vehicles. I’d be happy to move this to the RRS forum if that’s what we are talking about - you’ll get a better response there if that’s the case. 😊
    Aug 2010
    Sunbury, VIC
    Moved to the RRS forum at OP’s request once vehicle identity had been confirmed. Hopefully someone here may be able to assist. 👍
    Kilmore, VIC
    106.38 MB
    The first diagnostic I would do is to ascertain what is turning, and what is not. In gear, idle, handbrake on (chocked ideally and/or with helper applying the brakes firmly). If the front shaft is spinning then the problem is after that (ie. front diff centre, front half shafts, etc). If the rear shaft is spinning the problem is back there. If one half shaft is spinning and the other isn't then that also helps narrow it down. Basically follow the rotating bits until they don't rotate anymore and then look around there. Blown CVs usually burp out some grease and chew up the gaiter, that sort of thing. If no visible shafts are spinning it's in the transfer case or transmission (or the interface between them). From your symptoms it sounds a bit like transfer case input shaft maybe given you say the 'box goes through the gears? But hopefully something else (simpler and cheaper). The transmission to transfer case interface is a known potential issue (spline wear). Good luck.
    DiscoClax
    '94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
    '08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
    DiscoMick Guest
    If you lock the centre diff, does the vehicle move?
    If so you might have broken/disconnected the front driveshaft.
    Quote Originally Posted by DiscoMick View Post
    The only way you can lock the centre diff is to go into Rock Crawl - the cdl in these and the D3/D4 works differently to Defenders.
    Unlike defenders you realistically cannot remove the front driveshaft, lock the CDL and drive home. You could go into Rock Crawl and do it but it will be a slow drive home.
    NSW SW Slopes
    No manually lockable centre diff but select rock crawl whilst at off-road height and wheels straight ahead then see if the vehicle will move.
    Graeme - why haven't you developed an override system (like your LLAMS) that means that with a flick of a switch you can lock the CDL irrespective of what TR setting you are in
