Results 1 to 10 of 12
Thread: Correct installation of headers/extractors?
    Feb 2019
    Hi everyone, I'm new to AULRO so first a couple of lines to introduce myself, then a question.
    I'm Marcel, I'm 44 and I live in Melbourne. My partner Susy and I have a 21 month old daughter, Bindi-Rain, and a 13 year old Jack Russell, Chocolate. Last year I inherited a 1972 LWB early Series 3 from my late grandparents. It's a veteran of numerous outback trips and was looked after pretty well: kept out of the rain, serviced regularly and maintained in good running order. But this was no show-pony, it was a working vehicle and accumulated some light surface rust, some dents and scratches and a whole lot of little modifications (like the mallee root choke knob carved with a Swiss Army knife) that lend it character.
    I have vivid memories of camping trips in "the Land Rover" as a kid so this vehicle is rather special to me. Just the smell of the interior and the sound of the original 2.25 motor brings back happy memories of fun and adventure on dirt roads and country highways. I've taken it on with zero experience (but learning fast) as a restoration project. I'm not after a showroom finish, I want it to be a reliable touring and off-road vehicle, to look dignified and to last another 40 years. I'm going to strip it down to a rolling chassis, get rid of the surface rust, recondition bits that need it, replace a few things, paint one panel at a time and put it all back together.
    Now to my question.
    I've decided to keep the original 2.25 L motor which runs well but I want to squeeze a few more horsepower out of it. Step one is fitting a set of Redback extractors. This was done today by a local exhaust specialist, but I'm wondering if he did a dodgy job. Rather than connecting the extractors to the rest of the exhaust system with flanges, he inserted the extractor tube into the slightly larger diameter pipe going into the muffler and secured it with a bracket. This leaves a gap of a couple of mm (see photo) where you can feel exhaust gases leaking when the engine is idling. It's not a huge leak, more a gentle puff, but it's not insignificant.
    Is this something I should be concerned about? Would that leakage compromise the effectiveness of the extractors by reducing 'good' back pressure? Or might it actually improve them slightly by reducing 'bad' back pressure, that is, making the exhaust system less restrictive? On a test drive I did notice a mild performance improvement. It accelerated slightly quicker and held top gear on hills a little better. But I wonder if that leak is not allowing the extractors to reach their full potential, even without modifying the rest of the exhaust (which I'm reluctant to do in case it kills low-end torque)? Any thoughts would be much appreciated.
    Aug 2010
    Sunbury, VIC
    Welcome to the forum. 😊
    Yes, that looks dodgy to me - a slip joint that is exhaust tight is no dramas, but one that leaks is not. I’d be asking them to rectify this.
    One could argue that welding the pipes together could be an issue if the joint has to be separated at a later date - particularly if the last few mm of the extractors had to be cut off.
    So for me some sort of joint would be preferred - if it was me I would prefer either end be flared to fit a circular seal with a bolt together flange to hold it together. However failing that how he has done it with an exhaust clamp, whilst unsightly is Ok - my mufflers on my jag and 101 are similar, however they do not leak exhaust gas - it is actually a roadworthy issue. Your guy has either mismatched pipe sizes where one fits into the other or has not pushed them in far enough and the slots in the outer pipe that allow the clamp to tighten up are not fully covered by the internal pipe and are letting a bit of gas out.
    You need to take it back and as a minimum get the exhaust leaks fixed and preferably, though not essential, have a different method to the clamp of joining the pipes.
    May 2014
    Tamworth NSW
    Poor fit indeed, but nothing a $10 tube of exhaust gasket sealant won't fix.
    As for the performance aspects of this engine... negligible.
    -Mitch
    'El Burro' 2012 Defender 90.
    Feb 2019
    Thanks everyone.
    I took it back and he apologised, put roof and gutter silicone in the join and tightened the clamp. We'll see if the seal holds. If not I'll take it back.
    Marcel
    thats DAF.....
    roof silcone wont hold... tuned and driven right you'll get the 2.25 hi comp engine to glow the manifolds.....
    There is an argument that can be put forwards for a certain type of venturi setup in the exhaust that draws fresh air in post extractors to help "clean" the exhaust coming out the back of the pipe BUT.. for a series of that vintage... not an issue.
    More than happy to do a meet and greet with you at some point and close that exhaust up properly for you if you'd like.
    I am with Dave - the exhaust guy should have fixed this properly.
    Feb 2019
    He also put a small bead of sealant - presumably the same stuff - over the new manifold gasket that came with the extractors. So far it doesn't seem to have burnt or peeled, it looks OK.
    Internet forums are divided over whether ordinary silicone is OK for exhausts. Some people suggest it should be OK against the head, which is kept relatively cool by the cooling system, and downstream of the muffler where the gases emerge cooler. In my case it has been used just upstream of the muffler.
    In any case I found another reason not to trust the person who did the work: he left an inlet manifold bolt loose. It just needed a couple of extra washers and he either overlooked it or couldn't be bothered doing the job properly. After being charged $350 for the installation, which he said would be a bit tricky and time-consuming (that may well be true), I expect is a job well done. So I won't be going back to him.
    Thanks for the kind offer to meet up sometime and help me fix this properly. Send me a private message when it suits. Happy to pay for your time and any parts required and I'll throw in a case of beer as well. I do need some expert advice on this 'restoration lite' project and this is best done with someone having a look over my landy.
    I've booked in a full service with Series specialist Fred Smith in Bayswater. He seems to have a good reputation.
    Marcel
    Quote Originally Posted by Marce View Post
    In retrospect,
    That probably should have been your first clue while keeping one eye on your wallet, the other on the owner for you to engage R/lo and back slowly and carefully out of the place to a safe distance before giving it all available beans towards the specific direction of somewhere else.
    Im a hack and I dont think a set of extractors and a muffle joint for a series is that hard to make up.
    Oct 2014
    Northern NSW.Australia
    'Roof silicone wont hold'
    Experience, or Theory ????
    But I agree, the work should have been done correctly.
    whitehillbilly
