Results 1 to 8 of 8
Thread: Can someone identify this sensor
    Nov 2011
    East Gippsland
    While looking around under the bonnet of my 2008 D3 I noticed some insulation damage on the cables leading to the sensor shown in the photo. It is located behind the left side headlight.
    Peter
    NSW SW Slopes
    Is it a sensor or a blank terminator for equipment not fitted?
    St Helena,Melbourne
    1.13 MB
    That's what I was thinking but looks like the po has hooked into it ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Avoca Beach
    Outside temperature sensor for aircon?
    Regards Philip A
    NSW SW Slopes
    The outside temp sensor is in front of the radiator.
    I must admit that just looks like a connector not a sensor to me but maybe it does go to a sensor.
    Nov 2011
    East Gippsland
    Thanks, for the replies, the insulation on the cable is damaged. I will just tape it up.
    I was not sure if it was a temperature sensor, but looked like a dumb spot as air flow would be minimal.
    There are small plastic plus in it, so it could easily be a termination that I am not familiar with
    Peter
    St Helena,Melbourne
    1.13 MB
    Air temp sensor is mounted behind the bumper or if if a bull bar is fitted its moved to the rh chassis mount.
    1974 VW Kombi bus
