Results 1 to 10 of 14
Thread: Hot glovebox Disco2
    99.87 MB
    Hot glovebox Disco2
    Does anybody/everybody end up with a hot glovebox between the 2 fronts seats by any chance? If its not normal, doesn't anybody know why this happens by any chance?
    Thanks for any input.
    Slunnie
    Oct 2007
    Brisbane West
    Simon does it happen after you put a pie in it?
    99.87 MB
    Quote Originally Posted by ozscott View Post
    OMG, I had never thought of that! That also explains the "ding" after driving for 30mins!
    Slunnie
    Kingston, Tassie, OZ.
    ... I BET it was a minted lamb and pea pie, too!!!😬😬😬😥😥😥
    Sep 2013
    Darwin
    12.74 MB
    He thinks he has an optional extra, so it's where he warms his beer...
    If you've got rear climate control it could be a stuck flap in the ducting, or foam seal gone. I get a hot left leg in the drivers footwell.
    Transmission issue, some reflective material gone, hole in exhaust, short, coiled spare wire tucked away?
    99.87 MB
    Closure on this.
    If your centre glovebox is like a pie warmer then check if the handbrake cable bung is still in place. Mine had fallen out of place and I guess hot underbody air was being blown up into the cavity under the glovebox. Might be good to keep some fumes out of the cabin also!
    Slunnie
    May 2015
    Williamstown, Victoria
    That reminds me, where is my pie warmer?
    Build date 11th Oct 2003
    LROCV #1410
    99.87 MB
    Quote Originally Posted by Bohica View Post
    It was in my glovebox.
    Slunnie
    Mar 2020
    In the opposite direction, I've considered drilling some holes so that the vents under the centre console vent into the console instead.
    99.87 MB
    Quote Originally Posted by admiralranga View Post
    To cool the glovebox?
    It interesting, because under the centre console, there are 2 ducts from the HVACS system that run under the lips on each side that duct the air to those back vents. I think you'd be able to do that really easily, even running new ducts from the front.
    Slunnie
