Thread: Ashcroft Auto conversion for Puma
    iveco Guest
    Has anyone done an Auto conversion using Ashcroft's 4 speed ZF auto for the Defender.
    I think it's the same auto used in the Range Rover and Discovery.
    Thanks.
    George
    May 2006
    Woolgoolga
    I would be more inclined to use the Ford 6r80 box, you should be able to bolt it straight up to the puma engine, if parts are needed just get them from a ranger.
    I know Sheldon from Cor Conversions did an adapter for the 6r80 to the lt230, but as of last week he has shut up shop. He still may have parts to do it though.
    Apr 2011
    Windsor NSW
    me too
    Hi, I am also interested as I would like to auto my 2.2 puma, I know Momentum 4x4 in Wauchope NSW do them but not sure which kit ? Am really interested too to see who has had a successful conversion done and with what.
    Thanks,Alan
    iveco Guest
    Auto conversion for MY2010 Defender 2.4 Puma
    Quote Originally Posted by Vern View Post
    Ok that's interesting Vern. I would think that apart from the mechanical items there would also be some ECU remapping required.
    May 2006
    Woolgoolga
    Quote Originally Posted by iveco View Post
    Yeah, you can just run a stand alone ECU for the trans no worries.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    For 6r80 Quick 6 Stand-Alone Transmission Control
    my local auto specialist said ford removed bearings from the 6r80 box that are in the ZF. He said its a **** box. That said he worships the 6L90
    valve body clearance for the front prop shaft is a challenge. Forbyn make a wide body lt230 that would work
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    May 2006
    Woolgoolga
    Yeah that's the ECU he said.
    The 6r80 is supposed good for 1000hp just with an ECU tune, and lots of Nm too.
    I was trying to find pics Sheldon sent me of the 6r80 mated to the lt230, he had the adapter housing and shafts made ready to go. (Can only find the pic of the shafts)
    DiscoMick Guest
    It's a Ford engine, so wouldn't the Ford gearbox just mount up? Would a Ranger ECU work?
    Narre Warren South
    Quote Originally Posted by DiscoMick View Post
    6R80 also used in the diesel Territory (ZF in the petrol).
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    Yes the 6R80 will most likely bolt up to the 2.2 as is. Ford have a long standing modular system for engines and boxes. The back of the 6R80 doesn't bolt up to the LT230. The rear case of the MT82 is different to the rear case of a Ford derived MT82.
    the Ranger ECU will take feeds from the body control unit (BCU) and transmission control module (TCM). Likewise the TCM will take feed from the ECU. Unless you can code out the inter-reliance on each of the 3 computers you will find the ECU and TCM will have conniptions especially if the BCU is not in the equation. A stand alone takes an RPM feed and a few other feeds but can operate on its own shift table algorithm. One way to get around the Ranger BCU is to use the Ranger keys and ignition ring and use other essential bits in the Defender. Starting to get complicated. FYI - the OEM TCM for the 6R80 is in the valve body as a mechatronic unit. The US shift unit is just an intercept box that talks to the OEM TCM.
    MLD
