Results 1 to 10 of 17
Thread: What is this oil leak?
    Aug 2012
    Greenvale, Melbourne
    Hi folks, I am wondering whether anyone can identify source of this oil leak. Its clear yellowish colour and dripping from the cross member. I cannot see anything above.
    Its 2007 lr3 4.0 petrol and the car was sitting in the garage for bout 10 days.
    Thnx
    Dec 2009
    SW WA
    That is about as random a question as one could post, for what it's worth I think it's coolant
    Aug 2012
    Not coolant. Its certainly oil but I don’t think its engine oil as what i gathered from the dipstick engine oil currently is looking lot darker.
    Would that be tc or auto? My td5 has pink dex3 fluid but i have never seen what colour zf lifeguard is.
    Thnx anyways.
    Brisbane,some of the time.
    If its not engine oil,from the position of the leak,one would think it could only be Auto or transfer case.
    More like auto.
    Put it up on off road height,grab a torch and have a good look.
    Thats after putting a couple of stands under it incase it decides to lower.
    Sep 2014
    Baldivis WA
    Quote Originally Posted by janousek View Post
    Thnx anyways.
    LF6 is that colour when new. A lot darker when old. Transfer case oil is that colour too, and the fill point roughly lines up with the x member. However if cover plates are on, the oil migrates.
    Judging by the colour and location, I'd put my money on a blown Transfer case front or rear seal
    Jul 2016
    Blackstone
    Has the transfer case oil been changed recently? As others have said it looks like TC oil, but fairly new, not the colour of oil that’s been in for awhile.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Oct 2012
    Quote Originally Posted by SeanC View Post
    As I found out there’s a copper washer for the TB drain and fill plugs but not the diff plugs.
    Mar 2016
    Quote Originally Posted by PerthDisco View Post
    It’s next to impossible that the washer leaks, even if reused, assuming it’s tightened correctly.
    2007 Audi RS4 (B7)
    Apr 2016
    New South Wales
    Can I suggest you get on your back, slide under and take a better picture? Asking the group to diagnose a leak by looking at oil on the ground is just guessing
    Mar 2016
    Taste it. That’s a good way to find out. It might kill you, it might not.
    2007 Audi RS4 (B7)
