Results 1 to 6 of 6
Thread: Key remote
    Feb 2013
    Queensland
    Key remote
    Hi all are all discovery 2 key remotes 433mhz or are the face lift discos different to preface life discos I need to get two new remotes my ecu isn't the nnn type thanks all.
    Jul 2014
    west of Transylvania
    Two types available, detailed info here https://remotekey.co.uk/land-rover/l...ry-2-key-type/ , the ECU type is irrelevant, the receiver is important cos the fob must match with that, though if you find a bargain for different frequency fobs than the receiver you can buy a proper receiver and change that too then you are OK.
    Nov 2014
    Nirvana near Albany W.A.
    Australian cars are 315mhz up to 2000 my , then 433mhz after that
    Feb 2013
    Queensland
    My 02 disco is preface lift so I would be 315mhz.
    Nov 2011
    My D2 is a 2000 and it is 433MHz.
    If you have the old ones is it just the buttons that are broken. I had to replace the buttons on both of my remotes when I got the D2, and also bought a new one on ebay for around the $60-70 mark whilst waiting for the buttons to arrive and that was a mob here in Brisbane. You just need it programmed to the car then which if you have a diagnostic tool you should be able to do.
    I had to buy 10 so I still have a few left.
    Richard
    _____________________
    1985 V8 County 110
    1994 TDI Discovery 1
    2000 TD5 Discovery 2
    2010 TDCI Defender 110
    Land Rover Owners Club of Brisbane
    Nov 2014
    Quote Originally Posted by discorevy View Post
    Quote Originally Posted by laney View Post
    maybe my post was somehow unclear, your 2002 will be 433mhz .
