Results 1 to 6 of 6
Thread: Warn cam shaft turbo fix
    Irishrover Guest
    Hi all the Macanic telling me I probably have a warn camshaft not getting enough air in when opening as everyone here would have heard before. It's a 91 3.5 discovery1 with 210000on the clock my question is could you sling a turbo under the hood to force enough air in instead of doing a cam change
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Irishrover View Post
    You could but the cam would keep wearing. It'd also be cheaper to change the cam.
    Irishrover Guest
    Thanks for your support it was just a thought I had
    Quote Originally Posted by BradC View Post
    ...............and here I was thinking Warn had started making cams as well as winches when I saw the thread title.
    DL
    Brisbane, Inner East.
    If the camshaft is that worn it is likely the rest of the engine is also. Pull the engine and do a rebuild. Save yourself a lot of grief in the long run. Take into account the value of the vehicle. Is it worth spending several gorillas for a professional rebuild.
    Have you checked the valve opening? Get a dial indicator and a mag base and gauge the opening of each valve.
    URSUSMAJOR
    St Helena,Melbourne
    4.28 MB
    The cams on these are made of cheese sticks, new cam and lifters will do wonders as would a low mileage 3.9.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
