Results 1 to 10 of 14
Thread: Cracked Coupling Prop Shaft
    Feb 2006
    gosford
    The coupling around the prop shaft is starting to crack. At 110,000 klm's. Has any one else had this? I would have thought that even Land Rover would have made this component to last a little longer.
    If we are talking about the rubber donut - seems about rite. Mine went at 100,000 km with road use - they are cheap to buy and easy to replace.
    Some people replace with a unversal joint (different shaft required) but others stick by the donut as it does help a little to cushion drive line shocks - I do think they should be been listed as a service item for the 100,000k service though.
    Gazz
    Adelaide Hills - SA
    Reckon you were lucky to get to 110,000. Mine went at 50 something thousand. Mostly farm work though - quite a lot of low range stuff.
    tombraider Guest
    I did 3 in 30,000kms...
    Changed to UniJoint and never looked back for the next 80,000kms.
    You can get unijoints anywhere, donuts arent as easy to find!
    Mike
    Jul 2003
    Mine's done nearly 160k 8O .... starting to crack around the bolts
    Mahn England
    Ex 300Tdi Disco:
    99.87 MB
    They're about $120ea to replace. Just change them. IF you go to a uni type shafts its then about $70-100 for the 4 bolt pinion flange and about $300 for the tailshaft. Unless you get gnarly with it in the bush, the donuts will last though.
    This one was about 6 month old before I landed it wit a bit too much noise pedal. ops:
    Slunnie
    sheff Guest
    Slunny. Could you tell me what the bracket does that is bolted to the underside of the diff. housing? (on the pic)
    Many thanks sheff.
    tombraider Guest
    Harmonic Damper, standard on the rear diffs of Series 2 Discovery.
    Series 1 doesnt have one at the rear but does have one on the front diff.
    Mike
    british4wd Guest
    Slunnie,
    The dead coupling in the pic was it a GKN brand, there are some cheap and nasty ones on the market which do not last. I could not see any markings on the one in the pic.
    Alan Howard
    Feb 2006
    gosford
    Thanks all for the replies. Sounds like at 110,000 klm's out of mine I should not be whinging.
