Thread: Nearly joined the roasted D3 club today
    Ean Austral Guest
    Gday All,
    Driving the D3 today and noticed what I thought was steam coming out the front of the car , typically the temp gauge hadn't moved , no low coolant level warning on the message centre , pulled over , no smell of coolant , none under the car , pop the bonnet and how the car never caught on fire with the air hitting the smoking engine I am not sure , maybe because I had shut the car down.
    Closer look and the smell of diesel started to get my attention but couldnt find the culprit because of the smoke. Let it clear and a close look revealed fuel in the area of the 3 drivers side injectors. I wasn't far from home so cleaned it up and started the car and made it home.
    Close inspection reveals that the front injector , drivers side , the bleed off fitting that fits into the side of the injector and has a small U shaped clip holding it in , is working loose and diesel is leaking and dribbles down onto the EGR and ultimately the exhaust. I recently had work on the fuel system done so can only assume that after having been disturbed it hasn't been refitted correctly and have worn a groove in the fitting, or the clip has lost some of its tension , but will speak to the bloke who did the work first before I start attacking it much more.
    I am guessing if you were remote a well placed and tightened small cable tie would hold it to get you out of trouble , but I don't think the car was very far from going up in flames to be honest.
    Cheers Ean
    Kingston, Tassie, OZ.
    Mate those clips are a total disaster, I have had problems gettong them to stay put, in the end I had to use new ones as they must lose some of their tension when removed and refitted. 😥
    Ean Austral Guest
    Hey Justin, hope you both are well . I need to send you my new number as I started a new job that supplies me a phone.
    Are the clips easily sourced ? they look like a pain with the bottom pin being bent over , my next moved depending on what the indie says tomorrow is to bend the top 1 as well to hold it in as it being straight seems to let it move very easily.
    Cheers Ean
    Quote Originally Posted by Ean Austral View Post
    Cheers Ean
    Hi Ean, yes just got the number , thanks. Initially I bent them etc however it didnt work. I "procured" some from a supplier with what i imagine were warranty parts, destined for bin etc. How many do you want? I may have 1 left somewhere...
    Ean Austral Guest
    Hey mate , I have placed a strategic cable tie in position for the moment , felt like a surgeon with 2 pairs of long nose pliers getting in there , will call over and see leigh tomorrow and see what he says and will make a decision moving forward.
    If you find a stash and have a spare spare then I will take it off your hands but don't see yourself short.
    Thanks and Cheers Ean
    I'll take a squiz tomorrow.
    And yes it is like performing surgery
    Jul 2013
    Earlier this year I replaced the injector bleed off pipes - nearly lost one of those clips during the job. I reused my clips and haven't had an issue with them coming loose.
    I first noticed the leak when pulling up to inspect a house we where looking at buying - would have been interesting having the car burn down in someone elses driveway
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
