Results 1 to 6 of 6
Thread: Jerry can nozzle
    Feb 2017
    Jerry can nozzle
    Due to the Disco 4 having that fuel filler protection system (for accidental insertion of a petrol nozzle) does this pose any issue when filling up with a jerry-can filler?
    Better ask now then swear at the car when I’m out on the bush!
    Ean Austral Guest
    Jiggler hose may be a easy option ...
    Cheers Ean
    Oct 2014
    Quote Originally Posted by BrianElloy View Post
    No issues, just don't push the filler nozzle down too far.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    May 2018
    South Australia
    I did a trial before heading bush and you can inadvertently trip the lock with the can nozzle. I cut a short piece of alloy pipe (alloy broom handle), that was the perfect diameter to match a diesel filler nozzle. Only goes in so far and then is the perfect size for my can nozzles.
    Mar 2011
    Cairns
    Yes, can fire the miss-fuel safety trigger, if you push in too far (which isn't very far ha ha)
    I've refuelled from jerry's dozens of times now. I make sure there is a footrest to balance jerry on a propped leg, as its a slow process gravity feeding 20ltrs when holding a jerry, trying to keep it balanced in the right position.
    Mar 2016
    It does depend on the jerry. I have the metal one with the metal spout and it doesn’t go in far enough to be an issue, but the plastic ones with the plastic flexible nozzle tend to be more of an issue. Agree with the above that it can be tiring holding the can. Not as bad as feeding 20L of water into my camper. Now that’s painfully slow and painful on the arms, but I digress.
    2007 Audi RS4 (B7)
