Results 1 to 10 of 11
Thread: Can I suck Oil out?
    Nov 2013
    Wollongong
    Can I suck Oil out?
    I want to do intermediate oil changes on my SDV8. I have a suction pump but cannot get a tube down the pipe. I was wondering if there is another way? I will drop the oil for normal changes but for intermediate changes sucking out will do.
    NSW SW Slopes
    Whilst I haven't done it, I understand that the tube is meant to attach to and seal at the top of the pipe.
    Nov 2013
    Wollongong
    Thanks I will give this a try, have a vacuum pump so just need to organise some tubing. I will advise. My aim is to reduce dilution, tested oil last service and it was at 6% which although RR accept I feel is a little high.
    Sep 2012
    Adelaide Hills
    i think you should buy her dinner first
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Dec 2011
    You need to make up an adapter to seal against the top of the tube. I have done it a few times with no issues.
    Barry
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    Quote Originally Posted by Eevo View Post
    oh, woo her first......
    Jun 2008
    Quote Originally Posted by Bails View Post
    if you have a long enough straw , enjoy.
    Nov 2013
    Wollongong
    OK all good managed to change using the factory option of suction. Will send oil off for testing. Easy as purchased pump flee bay and with slight modification was able to empty oil. Will change filter at normal change which will be at the dealer.
    Nov 2013
    Wollongong
    OIl Test Back
    Oil test had better results for the shorter run time, which would be expected. Fe was down and dilution was at 4% which I think would get to 3% if I had changed a few k's earlier which was my intention. All up an easy job now I have the suction pump setup sorted. Pump out and refill without filter change is an easy job. I will do the normal changes at 25,000 k's. I wait for the oil spec to come on special and Buy so not to expensive.
    grab an old gas bottle, remove the valve after emtpying it, fill it with water, drill a hole in the top just smaller than the OD of some 8mm truck air line, slip some 13mm ID clear vac hose over the end of the 8mm and clamp that in place. Get a screw in adaptor for the neck of the bottle with a barb that suits your vac pump. (feel free to put a second section of clear near the gas bottle OR if your willing to spend the cash just use the vac hose for the whole length)
    Put the 13mm on and push it down past the flare in the extraction pipe head, leave the gas bottle on the ground and put vacuum on it for about a minute. start on spinning your filters checking your tyre pressures...... If you've done it on a warmed up engine in less than 10 minutes you're ready to fill it up again..
    And the bonus....
    if youve done it just right...
    when you're done with it, plug the engine end of the extraction hose onto the vac point of the gas bottle and then... take it to where you goto empty it hold the hose low turn the bottle upside down over the drain point and if you're in a hurry add a psi or 2 of pressure from any form of blower or compressor and done.
    and yes, any of the small good quality hand held battery operated matress inflator/deflators will make this thing work... (and the cheap 12v ones as well)
