Results 1 to 9 of 9
Thread: C shaped trim 'cover' for raw steel edge
    Adelaide Hills - SA
    Does anybody have the proper name for the flexible C section steel and rubber stuff that covers rough steel edges - probably 10 or 15mm deep.
    I have searched on trim + edge etc etc, so there must be a trade name for this stuff.
    I've cut/altered the hole in my winch bar (with a grinder) to fit a different winch, and I have raw edges that need covering, so it needs to slide over 2 or 3mm thickness steel.
    If you know where to get it, even better.
    I've got a roll of it but it is only rubber, not rubber and steel. It could be called grommetting material.
    Have a look at Scotts Old Auto Rubber
    http://www.scottsoldautorubber.com.au
    and
    http://www.scottsoldautorubber.com.au/page11.gif
    http://www.scottsoldautorubber.com.au/page12.gif
    http://www.scottsoldautorubber.com.au/page13.gif
    http://www.scottsoldautorubber.com.au/page14.gif
    A lot of their stuff can be bought by the metre. They aren't too far from me.
    Ron
    May 2002
    Heathcote (in "The Shire")
    You should be able to find it at a good auto parts place. I picked some up a couple of years ago from a local parts place to use on a roof console/shelf. Fitted over 2mm aluminium without any problems.
    Bushie
    Camp Hill Queensland
    saw this in clark rubber last time i was there. dunno what it was called
    Avoca Beach
    "PINCHWELD"= nylon stuff which has spring inside to go over steel.
    Regard s Philip A
    Toowoomba QLD.
    Regard s Philip A
    http://www.clarkrubber.com.au/index.php'se...846&pageID=4852
    Trev.
    Adelaide Hills - SA
    Well I never would have guessed PinchWeld!
    Thanks a 1,000,000. I'll go to my local Clarks Rubber and see what they've got.
    Nundle
    Pinch weld
    I've used this stuff on consoles and door pockets, but got it from the wreckers as there's metres of the stuff on most cars around door openings etc
    Perry
    SYDNEY -in the shire.....
    <span style="color:blue">yep....what he said.....
    just go to the nearest dumped car and you will find what you need....</span>
