Why would you bother - an oil pump from a Ford Dealer is less than $170.
May be worth considering at timing belt replacement time EXTRA 19.5 - oil pump for Land Rover & Range Rover Anyone translate from Russian is that a black eye?
Currently $182.50 from Ford.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
1974 VW Kombi bus
Despite the negative reply’s so far I think it’s a good idea to fit the uprated pump at cambelt change time.
Any increase in oil pressure has to be good. The engine is designed with a maximum 4.5 bar oil pressure, so providing the uprated pump keeps the pressure relief set to 4.5 bar there will be no issues. What’s more interesting is even with the new pump the oil pressure only reaches 4.0 bar @ 3000rpm according to the manufacturers website information, which is higher than the ‘worn’ factory pump but still below pressure relief activation.
There was brief talk on Disco4.com about a group buy for the pump.
2014, MY14 Discovery TDV6, Fuji White (2018-Now)
2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
hi all,
I will be shot for this but all the talk about the newer oil pump a necessity for anyone doing timing belts does not translate to most LR indies i know. Had timing belts done twice in two diff D3's over the years and both times at diff LR indies they said its not common to replace standard oil pump, just inspect and only replace if required. Both times original was used again without the need to replace for newer version. Just my experience. They do say its uncommon to change these as in their experience they have never had one fail. I know there are experiences out there where people have had problems but wonder whether the story has been exaggerated and is only a small percentage which have failed at the hands of people doing at home and over tightening the oil pump bolts causing subsequent problems.
Land Rover
1974 VW Kombi bus
