Page 1 of 8 123 ... LastLast
Results 1 to 10 of 74
Thread: Tdi Longevity
    Jul 2003
    Tdi Longevity
    Tdi's (both 200 and 300) have been around for nearly two decades.
    Prompted by a question posted on Outer Limits I thought it would be interesting to get some idea of the ages of Tdi's around.
    http://www.outerlimits4x4.com/PHP_Modules/...9b388edacc7a9aa
    Might be handy to also know if it is a 200 or 300 and if it is in need of a rebuild or has been rebuilt.....as well as any other relevant views.
    (Any chance of a temporary "sticky" on this Inc?)
    Mahn England
    Ex 300Tdi Disco:
    Jul 2003
    Mine has done nearly 160 k.
    Rebuilt at 40 k due to over heating.
    Going very nicely thank you with regular servicing (oil and filter at 5000 km)
    Mahn England
    Ex 300Tdi Disco:
    Yass NSW
    I voted but I don't have a TDI
    Jul 2003
    Well that worked
    It is a problem with polls that people who are interested aren't able to see the poll results because they aren't given the option to be a bystander. :wink: :roll:
    Mahn England
    Ex 300Tdi Disco:
    Daisy Hill Queensland
    Coming up to 200k 197k to be exact and still giving 10.5 l/100km
    Its ok but a little slow.
    Cheaper for cooling system parts than most other 4wds, but it does chew out lift pumps (now on third) belt tensioners (on second but needs a new one) and timing belts (at the 1/2 life of the third belt). Also needs injectors but these need to be replaced as told they can not be rebuilt.
    Some times i wonder if i would be better off in a V8,
    Has anyone done this on a V8 or TD5?
    :TakeABow:LAND ROVER
    Don't Follow Me, I'm in a "Land Rover", You WON'T make it.
    aut viam inveniam aut faciam
    Free Again Thanks Dan
    well ive only had my 300 Tdi defender for 4 months and as far as i know and going by the service record and its previous owner its never even had the head off
    200.000 ks not using a drop of oil between each service
    Just a general feeling I've been having from comments on the site, and my own experience, that it isn't that uncommon for injector pump to go just past 200kk. There have also been a fair number of other major issues coming up at about that mark.
    Or so it seems to me.
    Also, judging from the comments about fuel economy, there's a tiny margin of difference driving a brick with a roofrack, spotties, extra weight onboard, etc. I wonder if the variations that people have reported are more related to servicing and the work the engine has done.
    Mine has had the head off before it came to me, well-documented injection pump replaced, and is looking at a gearbox rebuild in the next few days/weeks. I can't think of a way that the injection pump would be affected by hard work/poor service intervals; I'm reasonably sure the head and the gearbox were.
    Simon
    SYDNEY -in the shire.....
    <span style="color:blue">ditto.....</span>
    I'd Rather Push My Land Rover in QLD Than Drive A Toyota in NSW
    The Disco 99
    157K for mine and Ive had it for the last 25K and apart from the issue of the coolant tank split issue and alternator at 150K everything else is ok (touch wood)
    5000km oil changes with penrite HPR15 used each time, small oil consumption about 300ml or so between changes
    95 Fender
    From near new (5000km) no issues with motor but found out that at 82K (about 7K after I sold it) the timing belt let go 8O 8O 8O it was before LR started the 80K then 60K change intervals
    97 Fender
    Belt and update housing fitted at 50K and only other issue was a lift pump around 80K or so, sold at 140K no other issues heard from the new buyer although it did go to SA
    Always have done 5K oils and until the disco used to use Castrol RX Super or Shell Rimula X
    Really I've got to sya that for me they had been a great little donk :wink:
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    mine has 211,000 + and never (touching wood while saying) had anything other than regular service items including timing belts etc etc
    5000k oil + filter changes
    a client of mine has a 97tdi disco that has 400,000 + on it and it threw a crankshaft pulley at approx 300000 from memory, $1500+ for the fix. it is considerably slower off the mark than mine but starts first time everytime.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
