Results 1 to 10 of 17
Thread: P2264 - It’s winter again
    Mar 2016
    Every winter the dear water in fuel error comes up. Each winter I think I’m not dealing with that in the wet. Each summer it stops happening and I don’t replace the entire unit. Each winter I kick myself.
    I did try getting the unit out a couple of months back but grovelling on the driveway I just couldn’t get the unit out past the subframe so gave up and simply changed the filter.
    I love my Disco
    2007 Audi RS4 (B7)
    Mar 2016
    And no, there’s never any water in the fuel when you drain it. I suspect the circuit gets moisture in it in the wet weather and flags a fault. I’d bypass the thing if I could work out how
    2007 Audi RS4 (B7)
    NSW SW Slopes
    When new mine would get water in the electrical connectors after driving through puddles. The silly warranty technician checked for water in the filter bowl rather than read my complaint properly so I just sealed the connectors in silicone.
    Mar 2016
    So you didn't remove the sensor, but coated all connectors in silicon to stop water interfering?
    2007 Audi RS4 (B7)
    NSW SW Slopes
    I sealed the connector on the sensor wire which was supposed to be waterproof.
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by DiscoJeffster View Post
    If its anything like mine (which it should be), just unplug the single wire going to the sensor in the bottom of the bowl.
    The previous owners mechanics did that on mine by discarding the sensor entirely (yay) and leaving the connector dangling. No alarms though.
    Mar 2016
    Quote Originally Posted by BradC View Post
    I wondered if it was that easy. Boom! Cheers. The day I do have water in the fuel I doubt it’ll actually work anyhow lol
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    Don't worry DJ, any water related issues will be mitigated by your oil leaks, boost pressure losses or susoension/transmission issues.
    Mar 2016
    Quote Originally Posted by Eric SDV6SE View Post
    Wow. I thought we were “brothers from another mother” given our similar issues. Bastard!
    New oil cooler arrived yesterday. New oil seals for the oil air separator in stock and will change just because I’m in there.
    Boost pressure is great thanks. Transmission is slick as. My new shocks and rebuilt compressor are going great. (Tongue emoji!!!!)
    And after all of this I still suspect my oil leaks are elsewhere. I can though confirm they’re not from the throttle! That’s fixed!!!
    2007 Audi RS4 (B7)
    Brisbane, Inner East.
    Maybe Uncle Ho can help. He once was a Land rover parts man.
    Ho, what are the LR part nos. for oil leaks?
    URSUSMAJOR
