Results 1 to 10 of 11
Thread: 2.7L TDV6 Aftermarket Instruments
    Oct 2011
    Fremantle WA
    For their 2.7L TDV6 specifically, or for other applicable generic D3/4 stuff, has anyone fitted aftermarket EMS gauges?
    I'm particularly interested in a D4 EGT gauge for towing my heavy brick through the centre and for hilly stuff (we don't have much of that in our WA sandplain country).
    The Madman gear has always impressed me, and they have a new easy read digital EGT gauge almost ready for sale in July - which may be too late for me - see Products | South Africa | Madman at EMS3. My 2.7 does NOT have an EGT sensor fitted, so will need a probe fitted.
    Q1 - currently agonising where to fit the probe and how much work is involved. It has just been suggested use the driver's/RHS exhaust manifold (more meat than the other side?) via a blanking kit to the EGR as per D2 TD5 etc.
    That in turn leads me to Q2 - With the D2, everyone recommended a coolant level warning gauge (which I had). I don't ever recall any such suggestion for the D3/4, which leads me to ask the obvious question - is there a factory version already fitted, and/or if not, is one warranted?
    Q3 - is the LR coolant temp gauge in the D4 actually a working version unlike the D2 and its predecessors which started climbing as the engine was about to self destruct?
    Q4 - I also have a penchance for knowing my ATF temp in the gearbox while towing, especially after reading the Ashcroft advice. I've heard conflicting stories as to whether my 6 speed auto has a sensor, with I think I recall a comment that the engine oil temp is similar and some use that????
    Over to the gurus!!!!
    Jul 2012
    Perth- South of the River
    Q1: Can't help.
    Q2: Factory fitted coolant level sensor is fitted to the expansion tank. My experience says it works well. This is until the float gets full (or whatever happens) and it sinks therefore reads low coolant permanently.
    Q3: Others will know this one better than me but the coolant temp guage must be on a range type set up. I watch my actual coolant temp via the gap tool move up and down without movement on the dash guage.
    However, I have had both the above work as designed (I guess) when a dumped a load of coolant on the Kwinana Freeway. Low coolant first, followed by a temp warning and the guage going up. Shut it down straigh away. Fixed the problem, filled it with cooant and away we went, no worries. That was two years ago.
    Q4: Transmission has a temp sensor. Can be read using the IIDGap tool.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Dagilmo View Post
    Q1: Can't help.
    thanks for prompt replies.
    Yep Later models (specifically 3.0L/ 8 speed) have transmission temp sensor, but I'm told not the 2.7 / 6 speed??
    Guess I'll have to learn more about this GAP Tool I was given, along withthe RovaCom IQ.
    Jul 2012
    Quote Originally Posted by gavinwibrow View Post
    Hi Gavin,
    All the information I quoted is for my 2005 D3 2.7 TDV6. 6 spped ZF.
    Only just got the D4.
    Cheers David.
    Oct 2011
    Fremantle WA
    Hi Gavin,
    Cheers David.
    In that case, good news at least in part. Many thanks
    Oct 2014
    Gavin, if you've not checked through available live values with the Gap iiD how are you sure there's no EGT sensor for the 2.7L ?
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Nov 2014
    Nirvana near Albany W.A.
    Dropped in on Darren today Gavin, your probe will be fitted to the RH ( drivers side ) manifold as there is plenty of room ( depth ) for the probe on that side.
    Q2-4 have already been answered by dagilmo
    Sep 2014
    Baldivis WA
    As far as I know the 2.7 and early 3.0l share the same 6speed ZF. It has a temp sensor, as I read mine off the diagnostic tool when filling the tramsmission after a fluid chamge.
    Mar 2016
    Q3. All coolant sensors report accurate temp to the ECU. The instrument pack has a range of approx 20-30 degrees where a temp within that range is considered “normal” eg 80-110degrees will read straight up on the dial. This is to stop people freaking out endlessly and pulling over etc when there is no need if the engine is operating within predefined criteria
    2007 Audi RS4 (B7)
    Oct 2011
    Fremantle WA
    Quote Originally Posted by LRD414 View Post
    According to my 2 local gurus who earn their living working on these horseless carriages yes there is none!
    Having said that, I will triple check.
