Results 1 to 6 of 6
Thread: Rear door seals D2
    Devonport, Tasmania
    Rear door seals D2
    Hi all,
    I am looking at a D2 with 150000 KM on the clock 1 owner.
    Where the rear door seals shut against the body it is back to shiny metal.
    I havn't noticed this on the D1's. Is this common due to different seals?
    Cheers Andy.
    Williams West Aust
    Hi Andy
    The Disco2 door seals arent the best.
    The common fix is to use "fly wire cord" inserted up inside the seals.This makes the seal thicker,stops water leaking in the rear door and cuts wind noise on side doors.
    Its possible the vehicle has had this done and the seal is now rubbing much harder on the door frame.Squeeze the seal and see if it feels like there is something inside.
    It could also indicate the vehicle has done alot of gravel road driving and the door is shaking against the frame.Look under the vehicle,any leading edges under there will show plenty of "sandblasting" from gravel if this is so.
    Best of luck,they are a great vehicle.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    How big is the spare? Could be dragging everything down.
    Simon
    May 2003
    On The Road
    the door should seal using the rubber ---
    if there is metal to metal something is wrong,,,, :?
    Golden Grove, Adelaide
    Mine is back to bare metal and never gets time to corrode. It is caused by coarse dust getting in between the rubber seal and the body, acting like sand paper as the door vibrates up and down. I believe it is a very good indication that the car has spent many many kms traversing corrugations (as mine has)
    The other areas are the leading edges of the rear wheel flares, bare metal and never corrode. The radiator suppot panel has bare metal where ever the plastic trim panels contact it. and all the leading edges underneath are shiny bare metal. The real ****er will be when I post back to Adelaide next year and I don't get to sandblast these areas on a daily basis. shiney metal will soon be rusty mess 8O
    If you are looking at buying it, know that it has probably done a lot of kms on dirt roads. Mine did not display this until it had been up here on the Cape for about 40,000kms. and it didn't get back to bare metal until it had done about 90,000km's. The other 2 series II's that have lived here and the 3 series I's have displayed the same thing and they live in the town so only get on the dirt on the weekends.
    99.87 MB
    My door seals are standard and one of the doors has rubber the paint. I'm also pretty sure its just grit vibrating inbetween the seal and the door.
    Slunnie
