Results 1 to 10 of 11
Thread: Whole host of confusing issues
    alexsully Guest
    Hi all,
    Yesterday morning, after hitting the brakes quite hard when someone pulled out on me, the car stopped changing gear. I slid it over to manual and it changed up and down fine. I have since realised that the issues with gear change are only when i have the driving lights turned on. Turn them off and the auto changes up and down without issue.
    I checked the lights and noticed that my right hand brake lights is not working. However, when I turn the driving lights on, my brake lights lock on as if the brake pedal has been pressed but the right hand brake light no longer illuminates and the left hand brake light, that wasn't working, does illuminate!!!
    I'm at a total loss!!!!
    Any help would be hugely appreciated.
    St Helena,Melbourne
    1.13 MB
    If its a D3 i would bet its the brake light switch, early D3 and could be the tail light bulbs as well.
    Sounds like the wiring for the spotties is a bit suss as too.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Nov 2015
    Black Rock
    What loanrangie says. Whether D3 or D4 check to see where the driving light pick up point is. My guess is that it is interfering with a canbus signal if it's a later model. To diagnose, I would disconnect the driving lights and see if you can duplicate the issue.
    It would help if you'd tell us what model and how the driving lights have been wired up.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Mar 2016
    Adelaide
    I think the problem is that your car is refusing to be nocturnal and only wants to be driven in the day time.
    Hope that helps!
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by DieselLSE View Post
    Unlikely to be a canbus issue. On a D3 it will be the switch and/or brake globes.
    The sudden stop my have pulled a tight cable or disconnected an earth.
    Oct 2012
    Yep 4 new (genuine LR) globes to the upper and lower brake lights solved similar confusion for me recently. Do before considering brake switch charge.
    Nov 2018
    Hobart, Tasmania
    Quote Originally Posted by alexsully View Post
    Hi all,
    I had an interesting & similar problem with my MY13 TDV6 the other day. Coming out of a local council playground (had grandchildren to amuse for a few hours) and slightly downhill with speed humps. Doing roughly 10 kph and as I went over the speed hump and took my foot off the accelerator to reduce the jolt thru the car, the trans coincidentally decided to change up from 1st to 2nd. The jolt thru the car caused by the speed hump and the upchange at same time somehow caused the trans to refuse to change into higher gears from that point on. I stopped the car, switched off the engine and re-started and no problems, the auto shift was fine. has never happened since. Go figure.
    alexsully Guest
    Thanks all for the suggestions.
    My boot release cable has come away from the mechanism but this is booked in with the mechanic on friday. Once that's fixed I'll set about changing all the bulbs and see if we get anywhere. If not, brake switch.
    Thanks again!!
    Jan 2012
    Quote Originally Posted by Discodicky View Post
    Reading this, I’ve also experienced similar. However I put it down to the car sensing no throttle input, going down hill, and holding the gears to arrest a run away. No need to restart....manually change gear with gear shift/paddle and all good.
    Apr 2012
    Whyalla, SA
    Save yourself a heap of cash and buy the new brake switch from Ford. A quick search will find the ford part number - it’s the exact switch (if you remove yours it will be stamped Ford) and significantly cheaper.
