Results 1 to 10 of 38
Thread: Puzzling behavior 300tdi
    Apr 2002
    Bellara 4507
    32.43 MB
    Went to check the coolant on the 130 this morning as i do, on my weekly check on all things under bonnet
    undo cap and woosh of air and a little coolant falls on the outside of the tank
    look inside the coolant tank and it is almost empty
    hmmmm
    check dipstick, the usual black stuff on the bottom, phew!
    refill coolant tank to just above the join as i normally do and start the engine up.
    bit of black smoke and the tiniest tinge of blue for 10 secs and then fairly clean as usual
    check the coolant tank whilst revving it a few times and no bubbles appear
    what should i do now other than peering longingly at my wallet ?
    pressure test the coolant system i suppose ...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Torres Straits
    Sorry to hear Inc
    You’ve made the diagnosis already
    It’s the HG
    The best / quickest / $ option is to order a new head from Turners, gasket set etc
    Park her up yoink the whole cooling system out
    Rodnthe radiator / replace the pump and Pgasket and long bolts / replace the thermostat / renew any dodgy hoses / replace or remove the ejector (it’s probably clagged) then when the head arrives swap em over and drive off into the sunset
    Otherwise you could try a bunch of other things muck around, pull the head off, try to fix it blah blah blah and in the end wish you just fixed it
    Sucks
    S
    Apr 2002
    Bellara 4507
    32.43 MB
    yeah...
    who do turners use for freight out here?
    and no real warning to boot dam it...
    Apr 2002
    Bellara 4507
    32.43 MB
    about $1400 worth for the head, bolts, gaskets shipping and plus the GST when it lands...
    oh well it is what it is i suppose
    St Helena,Melbourne
    4.28 MB
    Shop around, try Autopost in London.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2010
    Some pressure in the coolant system is normal, no? I often have air 'whoosh' when removing the cap.
    It might be worth using one of those combustion leak tester kits before u rip the head off.
    Also, the expansion cap is supposed to release over pressure.
    May 2008
    Bundaberg Qld
    Sniff test the header tank.
    Apr 2002
    Bellara 4507
    32.43 MB
    yeah but the header tank was next to empty and all i've done is turn it over for 5 or so mins once a week for the last few weeks as i've been to sore to use the clutch
    i've only just put a new genuine cap on the header tank
    i'll get the coolant system pressure tested as a starter.
    i swear land rovers are like dogs, they know when you sell something and have some project money.
    just had to spend $800+ on one of my dogs after it picked up a tick out of nowhere
    Torres Straits
    Inc
    We are only 85km from your joint
    If you wanted a hand once bits arrived I’m sure I could scooch down for some spanner tossing?
    S
    Torres Straits
    300tdi
    Using water
    Bubbles in reservoir
    Gonna be HG and quite likely a knackered head to boot
    Of course it doesn’t have to be but
    If it looks like a duck and quacks like a duck!!!
    I guess it takes what an hour or so to yoink the head off
    Could always do that and see what the HG looks like?
    Trouble is in my experience it’s very hard to test the head once it’s on a bench
    You will see cracks around the glow plugs
    You won’t see cracks in behind the valves???
    S
