Results 1 to 3 of 3
Thread: HVAC Ventilation Error Message
    Oct 2013
    Old Toongabbie, Sydney NSW
    Hi guys.
    Did a scan this evening with my GAP IID tool after it failed to connect immediately.
    Got the following fault code message.
    Model L319 - Discovery 4 2013
    Vehicle scanned on 14 Aug. 2019 22:18:28
    IIDControl 2.9.9.5 Build 69 Android - IIDTool BT V3.0 B2481
    HVAC-Ventilation
    B1083-01 (28) Recirculation damper motor - General failure information - general electrical failure
    ( on 23-07-2019 12:25:26 at 35512 km )
    Before I clear it, is this something to be worried about?
    Martin
    Tangambalanga
    I’m not sure I’d be overly worried about it. I’d clear it then find out how to fix it, if in deed you need to even have it. I guess though, being “recirculating”, you probably do need it, or will at least want it working at some point.
    Dec 2009
    Ranelagh, Tasmania
    I wouldn't worry about it. It occurred once in July. It isn't unusual for these cars to throw up errors which aren't real. Every time I scan I see something especially after more than a month. If you start seeing it regularly or it doesn't clear then you may have a problem.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
