Hi, I have had lots of problems with after market wheels on 2008 130, probable same as yours wobbles around 80 to 95Km had them balanced over and over again all the manage to do is change the speed range a bit. Solution is find a wheel balance machine that holds the wheel by the stud holes not the centre and problem solved.
Regards Dennis
 He said I would have to research for an aftermarket swivel hub adapter replacement to combat this or correct the castor a different way? Has anybody gone through this or heard of this before?
