Results 1 to 3 of 3
Thread: Changing Radiator & Turbo Hoses & Air Mass metre
    Gold Coast, Qld
    '99 Manual TD5 Disco - couple of questions
    1. I am about to change my top and bottom radiator hoses so can I just unclip them and go for it or do I need to drain anything or do anything before they are removed - same goes for my turbo hoses.
    2. I have sucked in a bit of dirty water through a gap in my air box and the air mass metre has a bit of dried dirt on it, a. will this affect it's operation b. can I clean it by hoing it down or c. what does a new one cost?
    Thanks in advance as I start to tackle some of these easier jobs myself, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Kurrajong Heights NSW
    Hi mate
    Got this quote from the UK for a TD5 MAF sensor, much cheaper than you can purchase locally:
    Dear Sir,
    Thank you for your recent enquiry Re: TD5 air flow meter
    We specialise in the field of MAIL ORDER, sending spares and accessories to countries all over the world on a daily basis, as well as domestic UK.
    We can supply either GENUINE LAND ROVER PARTS or alternative 'PATTERN' replacement parts of similar high quality.
    We also have a thriving second hand department which is constantly dismantling Land Rover, Range Rover and Discovery vehicles of all ages.
    As well as Nudge Bars, Side Steps, Light Guards and other accessories for 4x4 vehicles, we are also able to supply practically any other service item, body part, engine, gearbox etc. you may require.
    We are pleased to quote for the following items:-
    FF003730 air flow meter TD5 65.00
    Carriage to Australia 35.00 (DHL - delivery up to 5 working days)
    All prices exclude UK V.A.T. which is not charged on goods directly exported from the EC
    Import duties and Customs Clearance charges may be payable - please check with your local customs office
    Payment by CREDIT CARD is fine - please supply;
    Card number, Expiry Date and Card Holders Registered NAME and ADDRESS.
    We also need the last 3 numbers from the security number on the reverse of the card.
    We accept VISA, MASTERCARD, SOLO, EUROCARD, AMEX, SWITCH, MAESTRO & DELTA. You may also pay by £STERLING cheque (please allow time for cheque clearance)
    Please also provide a daytime CONTACT TELEPHONE NUMBER - we write this on the parcel in case of delivery difficulties - it is a requirement of the couriers that a telephone number is present.
    Please quote reference number in all correspondence.
    We look forward to hearing from you and assure you of our personal attention at all times.
    Yours faithfully,
    CHRIS BRIGGS Prices Valid 7 days from above date
    (EXPORT SALES) All prices are in GBP Sterling
    TEL. UK + (0) 1507 609444
    FAX. UK + (0) 1507 609555
    E-Mail CHRIS@famousfour.co.uk
    Web. http://www.Famousfour.co.uk
    Avoca Beach
    Make sure they post it by air parcel post and not DHL. By app you do not have to have a customs entry and it will be delivered to your door. ByDHL you run teh risk of having them do a custome entry and charging you $100 for teh privilege.
    BUT first check the sensor part of the MAF. Are the wires clean? If not spray them with electronic contact cleaner. I believe you can also brush them with something soft like a toothbrush, but you would probably have to pull it apart. I do not know what a TD5 MAF looks like.
    Regard s Philip A
