Thread: Endless Air install Td5 Defender
    Mar 2019
    Brisbane south side
    Has anyone got photos of an Endless Air install on a Td5 defender?
    I am test fitting at the moment and it is looking like it wont work..
    Bill
    Quote Originally Posted by Bill Wallace View Post
    Bill
    Hi Bill
    Not sure if you have A/C on your TD5 but if you do and don’t mind losing it you can just convert the A/C compressor to be the air compressor as I did in my 130. From there it’s just a mayor plumbing in the air lines, adding a grease nipple to the fill plug on the side and wiring in a switch on the dash to activate the magnetic clutch and a pressure switch to turn it on and off. I’ve had this setup for four years and it’s great + the passenger gets a lot more leg room.
    Can’t send you pics at the moment as I’m overseas for a month
    Nick
    Mar 2019
    Brisbane south side
    Nick,
    I do have aircon and dont want to get rid of it.
    99.87 MB
    Will it go where the ACE pump normally goes on the TD5?
    Slunnie
    Apr 2012
    Whyalla, SA
    Spend ages working on this back in 2001 and gave it up as a complexity that was easily met by a good compressor for most use and a tank.
    It’s serious work, custom idlers, brackets and mounts and will need custom belts to fit.
    The only version I’ve seen on a TD5 replaces the AC
    Apr 2012
    Whyalla, SA
    You can consider driving it off the PTO outlet.
    99.87 MB
    Thats a really good point with the development that happened with electric air compressors, especially the twin pumps. You probably don't even really need air tanks apart from the small integrated ones for diff lockers.
    Slunnie
