Results 1 to 4 of 4
Thread: Air strut dates?
    Apr 2017
    Bribie Island
    Air strut dates?
    It was my understanding that you could read the manufacturing date from the sticker on the strut. The unit in question is marked Land Rover BWI so I think it is genuine?
    The vehicle is a 2/11 D4. Any thoughts?
    They are front struts. One shows a valid date and time the other shows crap.
    The car has a small overnight drop at front. If it is the odd strut what are your thoughts on replacing just one unit.
    Rear struts have 2016 dates.
    Dec 2014
    Branxton, NSW, Australia
    If they’re only 3 years old it probably isn’t the strut. They potentially could last 200,000km, mine did anyway. Most likely a leak in the front valve block. Check the bag anyway, inflate to off road height and spray soapy water around the bag.
    Current - Silver 2007 SE D3
    2005 Defender 110 Wagon TD5 - Gone :(
    St Helena,Melbourne
    1.13 MB
    If it drops evenly then its the valve block.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2010
    Central Coast NSW
    Only if you disconnect the self levelling fuse otherwise the car will drop evenly.
