Originally Posted by
Gerard_A
..... The solutions from Exmoor trim are a bit pricey and was wondering if anyone has found any decent alternatives?
How keen are you on DIY solutions that you will need to organise?
If you don't mind buys material and cutting up yourself, you're in Melb(don't say where), and so if close to Blackburn I recommend you go check out Megasorber.
Google them, but as a rouge guide they're just off Middleborough rd, just south of the Doncaster Freeway.
They have a warehouse .. almost store type frontage, and a display of products. I bought direct from them.
I got their Megasorber foam vinyl sound barrier stuff(sorry can't remember exactly which type, but can check if needed) .. about an inch thick.
I used it on my D1(tdi) engine side of the firewall.
I got two large squares of the stuff, one adhesive backed(more expensive) and the other sheet same stuff, non adhesive. I still have the adhesive backed stuff complete, sheet I think is about 1.5m x 1.5m square.
Both sheets cost about $160.
In a word brilliant. Ive used sound proofing before, on my RRC(79, with LT95) mainly on the floor to cut the screaming transfer gears. Worked a little, not as good as I hoped but better than nothing.
This stuff from megsorber tho I think has been a bit better in minimising the tdi yelling and rattling .. more so when cruising along than when accelerating tho.
Megasorber claim the stuff(I got) is totally fireproof, which I tested of course, with one of those cheapo butane gas torches. So far(for my needs), has been impervious to what I wanted it for.
The 1.5m sheet was too much for the D1 firewall, I cut it into large as possible pieces and stuffed it against the firewall where I could, a double layer near the brake master cyl too.
Had left over to cover some of the bell housing, again only where I could, and not interfere with linkages(mines auto). And still a large enough piece(s) remained, didn't know what to do with but eventually decided an engine blanket too.
my original plan was to do firewall with non sticky and do bonnet insulation with the adhesive sheet too .. but have procrastinated on the bonnet sheet(still deciding on the adhesive sheet)
One of the other things I wanted from this material was that on my tdi, one of the heater hoses needs to sit against the tappet cover. I got it like this, and the rubber hose had melted in having sat this way. I immediately insulated it with an old ruibber hose cut up, but that rubber hose also wears and burns, so had to keep eyes on it. So with this megasorber I wanted a totally heat/fire/flame proof bit so set and forget. Did the trick no worries
So their claim of fire/hat proofing is dead on, and as I said of course I had to test it with the torch too.
The piece I sheeting I added over the gearbox/transfer(just small piece) was to help eliminate the heat you'd get at the flood/carpet near your thighs(left driver/right passenger) .. worked good too.
Note, being 25(ish) mm or 1 inch thick, is no good for door application like you'd use for anti drumming/resonance noises.
Can be used for floor applications(eg. under carpet) as it can compress, but it doesn't stay compressed unless it's physically compressed. I'm thinking of using it on the rear floor, around seat under seat and boot space. Will help to cut down tyre droning.
Have done it, but I don't think it'd work well on floor under carpet(eg. at your feet) tho. It's too spongy and would feel wrong.
In that type of application, you'd do it from under car, either with the adhesive backed type of a contact glued application of the non adhesive. Also have plans to do this under floor, especially between muffler under the passenger feet.
Does work, Can't say exactly how much noise it cut, D1 when cruising isn't overly noisy to begin with, but on acceleration it's typical 300Tdi. Definitely noted a large enough difference on that first drive once I hit 80 on the freeway not far from me(Tulla-> Calder). Estimation of about 25% or so at least. Around town when accelerating tho, not as much. I've noticed that it's the drony low frequency sound of the exhaust that bugs me more(than say tdi rattling). Hence why my plan to cover under floor near muffler. I reckon this stuff would easily take the heat of a muffler, and most likely the stones getting hurled at it too for abrasion resistance.
Note this is just the 25mm stuff I got. They have a range of stuff on show at the office(HQ), and my trip there, the woman that saw me was more than happy to spend time to help.
I did check out other products via various online locations(ebay, other sellers, aliexpress, checked videos and writeups on what other folks think of the stuff they had access too and whatever comparisons ...
But I'm too cynical(when it comes to internet) comparisons .. trying to work out the testers form the product placers!
So I prefer to do real business, where possible.
Hope that helps.
Arthur.
'03 D2 Td5 Auto
'03 D2a Td5 Auto
