Results 1 to 8 of 8
Thread: D2 Rear Parking Sensors.
    LoadedDisco Guest
    I am going to put a steel rear bar on my Disco D2. I have been informed that the parking sensors will not work on a steel rear bar.
    Is this true or a wife’s tale
    If I have to remove the sensors for the steel rear bar where is the main parking sensor unit located so I can remove that and sell it.
    If I could keep them that would be great as they are useful for dogging trees when in reverse, not just the car park at the shops.
    Any help would be appreciated.
    Pennant Hills, Sydney
    we fitted a parking sensor to a front end loader that was working in a confined space they seemed to work fine used to bits of metal with holes for the sensors welded on top of the counter weight (one large hunk of metal)
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    Jul 2003
    <div class='quotetop'>QUOTE(LoadedDisco &#064; May 17 2006, 04&#58;39 PM) Quoted post</div><div class='quotemain'>
    [/b][/quote]
    I thought that they were ultrasonic so metal should make little difference
    Mahn England
    Ex 300Tdi Disco:
    LoadedDisco Guest
    Interesting info thanks.
    Jul 2003
    I noticed this in general chat:
    http://www.aulro.com/af/index.php'showtopic=11840
    The steel Kaymar rear bar can accommodate them.
    Mahn England
    Ex 300Tdi Disco:
    Queensland
    Off topic slightly but can anybody recommend a good quality after market parking sensor kit.
    I’d like to fit them front and rear on the RR.
    Cheers.
    Jul 2003
    <div class='quotetop'>QUOTE(drivesafe &#064; May 18 2006, 08&#58;33 AM) Quoted post</div><div class='quotemain'>
    Cheers.
    [/b][/quote]
    Hi Tim,
    Jaycar have a two channel model.
    www.jaycar.com.au
    I have the surface mounted model on the rear of the disco but they also have a flush mounted version.
    Sensor
    Autobarn carry a more sophisticated version. I think it is a four channel model.
    Mahn England
    Ex 300Tdi Disco:
    Queensland
    Thanks Mahn, I’ll look into them.
    Cheers.
