Results 1 to 10 of 12
Thread: SDV6 transplant
    Dfer Guest
    SDV6 transplant
    Hi,
    I have the much occurring crank failure in my SDV6 engine of my 2012 RRS. I am searching for a replacement used engine.
    Can the 3.0 litre SDV6 or TDV6 from a later model, ie. L494 from 2013 onwards, be transplanted into my 2012 L320 RRS?
    Jan 2014
    Perth Western Australia
    Yes, the 3.0lt engine is the same.
    Used engines from a wrecker, $10K - $15K and you risk it failing again.
    $25K or there abouts for a new crate engine.
    $5K or there abouts to install either option.
    For a vehicle worth about the same as the repair bill.
    Daz
    Dfer Guest
    Quote Originally Posted by DazzaTD5 View Post
    Thanks Daz...You summed up my dilemma very well. I’m paying about 2/3rds of the value of the car to getting it running again; and then tossing a coin as to whether it will do it again...
    Brisbane, Queensland
    These are such nice motors when they are running. But these are the numbers that really put me off a L405 & L494. I would like a L405 with 18” compos.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Dfer Guest
    Update....I have confirmed with JLR Aust that the TDV6 in the L494 model has a single turbo; whereas the SDV6 in the L494 has the sequential bi-turbo.
    So my revised question is can a SDV6 from a L494 be transplanted (easily) into a SDV6 powered L320?
    But you are really only after a long engine and all your old ancilliaries including turbos would come across from your old engine to the new engine.
    Jan 2014
    If its a 2.7lt out of a Land Rover its a single turbo (TDV6)
    if its a 3.0lt out of a Land Rover its a twin turbo (TDV6 or SDV6)
    doesnt matter the tdv6 or sdv6 designation.
    Daz
    Dfer Guest
    Quote Originally Posted by 101RRS View Post
    You’re correct. I was attempting to avoid any possible incompatibility with the figment of my controls and accessories to the later model engine block. Typically it is the accessories which get updated over time!
    For instance, are the engine block turbo recovery inlets the same between the blocks? I would assume so, but I’m not sure!
    Quote Originally Posted by Dfer View Post
    I am with the implication of DazzaTD5's post - you have been given wrong information from JLR Aust - all 3.0 TDV6/SDV6 engines are sequential turbos (2x turbos) - may have different power outputs but all have 2 turbos.
    Dfer Guest
    Guys I found this post on another forum here.
    "For MY 2014 & 2015.0 the TDV6 and SDV6 are mechanically the same engine with a double (sequential) turbo with different ECU programming. From MY 2015.5 the TDV6 only has a single turbo, but with a more aggressive & efficient ECU programming so the power and torque remain the same with less fuel consumption. The SDV6 (still double turbo) has received new ECU tuning which has increased the power and torque."
    This may explain the confusion.
    The low pressure EGR system was fitted on the TDV6 at the same time as going to the single turbo.”
