7th November 2019, 04:33 PM
Oil Pressure Connection for TM4
Hi guys,
Im almost done fitting a TM4 Engine Watchdog to the Fantom all I have left to do is to connect Oil Pressure wire.
Just been searching all over rave Electrical Troubleshooting & diagrams trying to identify the wire which comes from instrument cluster (Z142) connector number (C242) to activate oil pressure warning light!
As Tm4 has audible alarm it would make use of oil sender. I could tap into wire in engine bay but getting to the sender is a PITA.
If anyone has an alternate diagram that could assist it would make life a little easier to connect under dash, hoping someone can help out!
Martin
