Thread: Removal of D pillars
    I cant remove the D pillar covers to respray. Screws all out, pulled hard to the point of not wanting to break them. Any ideas?
    Feb 2013
    Gosford, NSW, Australia
    I just used some trim removal tools to loosen the clips which hold it on
    Steve
    Jan 2016
    Netherlands
    I got them out recently. IIRC pull at the top and slide them out upwards but I'll have a look when I get home. The old plastic does break a lot though, no matter how careful you are at times.
    -P
    Ok thanks, ill try to pull upwards and see what happens.
    Jan 2016
    Netherlands
    Hi mate, look at the image below. You need to remove the rubber lining first, shove a breakerbar or flat piece of wood in and possible twist it to release the clips on the window end. Once you have done that just pull upwards and out.
    Cheers!
    -P
    Quote Originally Posted by prelude View Post
    Cheers!
    -P
    Thanks heaps thats my weekend job
    Cheers!
    -P
    Thanks got them off, very tough job, got them sprayed up and looking perfect
