Results 1 to 10 of 16
Thread: Rear end clunk
    Rear end clunk
    I'm a mechanical numpty so please excuse the "clunk" description.
    When accelerating away from a standing start (or near to) into a 90 deg turn (L or R) I hear and feel a clunk from the rear end. Think of exiting a driveway. The clunk is not loud or harsh and feels like I've run over a small rock or some such. Otherwise the car makes no noise from the rear end at any other time.
    Diff issue?
    MY18 D5 SD4 with no eDiff and 46k on it.
    Cheers.
    Mark
    Brisbane, Queensland
    Rear end clunk
    I’m thinking suspension. It should be under warranty still. I would get JLRA to look at it ASAP.
    Something easy to check (but pretty unlikely) is loose wheel nuts. I’ve had the experience of the 110 going in for work and the shop forgetting to tighten a wheel’s nuts. A couple of weeks later they had all loosened off and the wheel came off.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Nov 2012
    Annandale, Sydney
    One of my rear shocks had gone at 50k kms. Sounded similar to your description but when going over bumps. Both rears replaced under warranty.
    Tony
    Dec 2011
    Forrestfield WA
    It could actually be the callibration of the transfer case causing it. It was a fault picked up by LR and listed on Topix for the L405 and I think someone also had the problem on a D4. It is usually solved by changing the transfer case oil and then recallibrating the transfer case. The dealer would need to do it but it might be hard for them to diagnose.
    The transfer case tends to grab a bit (sort of locked up for a short time), which means that when relative movement is required between front and rear while turning a corner, for instance, it needs to inlock and does this a bit violently since it has wrongly locked, so there is a clunk usually from the rear diff due to the sudden shock. I thought my L405 had stripped rear diff teeth when I got it second hand, but it was just the transfer case issue and the above treatment fixed it. If they can diagnose it properly it will be a warranty fix. With mine it happened worst when accelerating around a slow speed right hand 90 degree corner (such as coming out of a drive way or at a T junction).
    You can also try driving in sand on a beach for few minutes. If there are a few clunks from the rear when you drive back onto the bitumen until the transfer case properly unlocks, it will be the transfer case issue for sure. That was the other symptom with mine.
    Just something else to look at if diff issues are ruled out and if you can convince the dealer to check for that. The cure is on Topix for them to follow if it is the TC calibration.
    Bob
    So after having the car for a day LR say its the tyres (Pirelli Scorpion all terrain plus 275/55R20) causing the rear diff to lock on tight 90° corners. These tyres are 25mm wider and 22mm bigger in diameter than the OEM 255/55R20.
    I find this a little strange as the tyres have been on for a year and 32k but maybe they've reached a point of wear to cause this? They look almost brand new to me.
    LR said they considered "calibrating" the diff (how is this done?) to the tyres but decided not to as it would need to be undone if/when I changed tyres.
    The wash up was that LR said its the tyres and not to worry about it. So I won't.
    inbar krasny Guest
    Dear friend.
    what was the solution eventually? did you manage to solve the problem?
    Diff issue?
    Cheers.
    Mark
    IK,
    No solution. LR said they could reset the diff for the new tyres but that would mean it would need resetting again when those tyres are replaced. I've since changed to Yokohama Geolandar CV G058 255/55 which are the same size as the original OEM and while the problem has lessened, its still there.
    NSW SW Slopes
    Reset the diff? About the only thing that an be done to an open diff is to set up the CW&P backlash properly and no wheel or tyre size will affect that!
    Have you checked that it's not an e-diff, assuming that you know what to look for?
    No e-diff.
    Dec 2011
    Forrestfield WA
    No e-diff.
    See my post #4 above. The centre ediff causes this issue. It doesn't have to have a rear ediff, although that can also cause the problem. It is a known problem on Topix, especially for early L405 Range Rovers.
    Topix says to do two transfer case oil changes and then recalibrate the transfer case. When turning corners the centre diff also has to be released due to the different speed between the front and rear axles. If not properly released there is a loud clunk from the rear end as it slips. This happens when accelerating around corners, such as T Junctions, after slowing or stopping for the intersection but will also clunk when coming off a beach onto a hard surface, for example.
    Its nothing to do with tyres or the rear diff, even though it fells like the rear diff has a tooth missing on the crown gear when it happens. I had it on my L405 and heaps of people are having it on their D5's, although they ignore anything I say about the transfer case causing the problem and continue to blame the ediff if they have one, even after the problem continues when they get it replaced under warranty. Just ask the dealer to recalibrate the transfer case and change the oil, as per the Topix information.
    Bob
