Thread: Mirror switch
    Graedeb Guest
    Mirror switch
    We are happy owners of a 05 discovery hse v8 loving the car , have a issue with mirrors , switch only makes them go down no up and left no right tried disabling the auto memory set thingamy but can’t get into settings either , on the stalk push button get to menu go to press the steering wheel buttons to scroll to mirror settings nothing happens ,any ideas , have tried another switch for mirrors still the same attached pic of our disco D791CFBB-2ABD-4AFD-A6AB-1DC95C9BA6A0.jpg
    St Helena,Melbourne
    1.13 MB
    Might need a soft reset.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Graedeb Guest
    Aha can you explain how or does rover mechanic need to do it thanks for reply
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Graedeb View Post
    You can do a hard reset by removing both battery clamps and touching them together , soft reset as I just found out is done with a diagnostic tool.
    1974 VW Kombi bus
    Adelaide Hills. South Australia
    I believe Land Rover side mirrors have a sad history of failing due to the crap design of the planetary motor drive from the D1 & who knows how far up the range this crappery went?
    Made worse by the physical body contact of passers by squeezing their way past pushing the mirrors & housings out of alignment.
    Would an 05 Discovery have the same poor setup? Did Land Rover learn from the poor & unreliable D1 design?
