Results 1 to 6 of 6
Thread: Soft hard resets
    Graedeb Guest
    Soft hard resets
    Sorry new to this site , having trouble navigating but finding my way around , in reference to my mirror switch issues someone suggested soft reset , tried but didn’t work with issues ,was mentioned needs to be done with diagnostic tool ? Is it safe to do hard reset as described in google searches I am wondering , spoke to a rover parts dealer with a discovery 3 regarding the set program on stalk to get into menu change and select with steering wheel buttons he said his didn’t work either is this a common problem or glitche thought if I set the mirrors in this menu it may help ,not sure at all
    St Helena,Melbourne
    4.28 MB
    A hard reset won't hurt and can be done without any special tools, soft reset is done using a diagnostic tool.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2013
    Bittern Vic
    I thought a soft reset was removing the battery terminals from the battery for a minute or two.
    And i thought a hard reset was joing the battery terminals together after removing them from the battery ???
    Ian
    Bittern
    St Helena,Melbourne
    4.28 MB
    With a gap tool a soft reset just does the ECU's and you don't lose any settings, st the battery you will.
    1974 VW Kombi bus
    Graedeb Guest
    Thanks what’s a gap tool
    Mar 2016
    Quote Originally Posted by Graedeb View Post
    As a specialist in investigations, I have access to many specialist OSINT tools. Here is the output of one of them. It’s amazing what it can find with only the simplest search terms. Soft hard resets
    2007 Audi RS4 (B7)
